im trying to launch isaac sim 2021.1.1 from the omniverse launcher.
the app window with the different choices comes up fine.
i pick “Isaac Sim” the first choice from the launcher and it crashes.
i have a geforce rtx 2070 with 16gb computer ram on ubuntu 1804
so ran it from the command line
/home/meta/.local/share/ov/pkg/isaac_sim-2021.1.1/isaac-sim.sh -v
and i get the following errors
2021-11-20 18:02:20 [2,883ms] [Info] [carb] Registered plugin: rtx.mdltranslator.plugin (interfaces: [rtx::mdltranslator::MdlTranslator v0.9]) (impl: rtx.mdltranslator.plugin)
2021-11-20 18:02:20 [3,081ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-11-20 18:02:20 [3,081ms] [Fatal] [carb.crashreporter-breakpad.plugin] libNRD.so.1!_init
2021-11-20 18:02:20 [3,085ms] [Fatal] [carb.crashreporter-breakpad.plugin] ld-linux-x86-64.so.2!_dl_rtld_di_serinfo
2021-11-20 18:02:20 [3,089ms] [Fatal] [carb.crashreporter-breakpad.plugin] ld-linux-x86-64.so.2!_dl_find_dso_for_object
2021-11-20 18:02:20 [3,093ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!_dl_catch_exception
2021-11-20 18:02:20 [3,096ms] [Fatal] [carb.crashreporter-breakpad.plugin] ld-linux-x86-64.so.2!_dl_find_dso_for_object
2021-11-20 18:02:20 [3,102ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!_dl_catch_exception
2021-11-20 18:02:20 [3,105ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!_dl_catch_error
2021-11-20 18:02:20 [3,108ms] [Fatal] [carb.crashreporter-breakpad.plugin] libdl.so.2!dlerror
2021-11-20 18:02:20 [3,111ms] [Fatal] [carb.crashreporter-breakpad.plugin] libdl.so.2!dlopen
2021-11-20 18:02:20 [3,114ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStop
2021-11-20 18:02:20 [3,117ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStop
2021-11-20 18:02:20 [3,120ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStop
2021-11-20 18:02:20 [3,123ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2021-11-20 18:02:20 [3,127ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2021-11-20 18:02:20 [3,129ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-11-20 18:02:20 [3,132ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!carbOnPluginShutdown
2021-11-20 18:02:20 [3,135ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long&&)
2021-11-20 18:02:20 [3,138ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-11-20 18:02:20 [3,141ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-11-20 18:02:20 [3,144ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-11-20 18:02:20 [3,146ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-11-20 18:02:20 [3,146ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-11-20 18:02:20 [3,149ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-11-20 18:02:20 [3,149ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Illegal instruction (core dumped)
