apparently I cannot install IsaacSim. I’ve an NVIDIA RTX 2080 Ti. I’ve tried both the latest 510 and 470 drivers installed by command line.
CPU is a server CPU with 12 threads. Should be sufficient.
Here is the log.
2022-06-03 15:55:25 [18,508ms] [Info] [carb] Registered plugin: rtx.raytracing.plugin (interfaces: [rtx::raytracing::AmbientOcclusion v0.2],[rtx::raytracing::AovConverter v0.1],[rtx::raytracing::Caustics v0.2],[rtx::raytracing::Compositing v0.2],[rtx::raytracing::CopyDepth v0.2],[rtx::raytracing::DebugView v0.3],[rtx::raytracing::DirectLightingLtc v0.1],[rtx::raytracing::DirectLightingSampled v0.1],[rtx::raytracing::GBuffer v0.1],[rtx::raytracing::GlobalVolumetricEffects v0.2],[rtx::raytracing::IndirectDiffuse v0.2],[rtx::raytracing::LightspeedAperture v0.1],[rtx::raytracing::MaterialBaking v0.1],[rtx::raytracing::PathTracing v0.4],[rtx::raytracing::Picking v0.2],[rtx::raytracing::PrimaryRayForwardLit v0.1],[rtx::raytracing::Reflections v0.3],[rtx::raytracing::SamplerFeedback v0.3],[rtx::raytracing::Selection v0.1],[rtx::raytracing::Shadows v0.2],[rtx::raytracing::SpatialHashGrid v0.2],[rtx::raytracing::Subsurface v0.1],[rtx::raytracing::SyntheticAttributeData v0.1],[rtx::raytracing::SyntheticImageData v0.1],[rtx::raytracing::Translucency v0.3]) (impl: rtx.raytracing.plugin)
2022-06-03 15:55:26 [18,983ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2022-06-03 15:55:26 [18,984ms] [Fatal] [carb.crashreporter-breakpad.plugin] libNRD.so.1!_init
2022-06-03 15:55:26 [18,991ms] [Fatal] [carb.crashreporter-breakpad.plugin] ld-linux-x86-64.so.2!_dl_rtld_di_serinfo
2022-06-03 15:55:26 [18,997ms] [Fatal] [carb.crashreporter-breakpad.plugin] ld-linux-x86-64.so.2!_dl_rtld_di_serinfo
2022-06-03 15:55:26 [19,004ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!_dl_catch_exception
2022-06-03 15:55:26 [19,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] ld-linux-x86-64.so.2!_dl_find_dso_for_object2022-06-03 15:55:26 [19,018ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!_dl_catch_exception
2022-06-03 15:55:26 [19,024ms] [Fatal] [carb.crashreporter-breakpad.plugin] ld-linux-x86-64.so.2!_dl_find_dso_for_object2022-06-03 15:55:26 [19,031ms] [Fatal] [carb.crashreporter-breakpad.plugin] libdl.so.2!+0x134c
2022-06-03 15:55:26 [19,038ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!_dl_catch_exception
2022-06-03 15:55:26 [19,045ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!_dl_catch_error
2022-06-03 15:55:26 [19,051ms] [Fatal] [carb.crashreporter-breakpad.plugin] libdl.so.2!dlerror
2022-06-03 15:55:26 [19,058ms] [Fatal] [carb.crashreporter-breakpad.plugin] libdl.so.2!dlopen
2022-06-03 15:55:26 [19,065ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStart
2022-06-03 15:55:26 [19,071ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStart
2022-06-03 15:55:26 [19,078ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStart
2022-06-03 15:55:26 [19,085ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2022-06-03 15:55:26 [19,092ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2022-06-03 15:55:26 [19,098ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2022-06-03 15:55:26 [19,104ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!carbOnPluginShutdown
2022-06-03 15:55:26 [19,111ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)
2022-06-03 15:55:26 [19,117ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2022-06-03 15:55:26 [19,124ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2022-06-03 15:55:26 [19,130ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2022-06-03 15:55:26 [19,136ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2022-06-03 15:55:26 [19,143ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)
2022-06-03 15:55:26 [19,150ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2022-06-03 15:55:26 [19,150ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2022-06-03 15:55:26 [19,156ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2022-06-03 15:55:26 [19,157ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Can you help me out?
pc is in a clean state, just formatted.
