I’m trying to launch Isaac Sim 4.5.0 on Windows 11 with an NVIDIA GeForce RTX 4050 Laptop GPU, but the application crashes immediately with a segmentation fault.
I tried to reinstall the GPU driver using DDU (Display Driver Uninstaller) in Safe Mode. However, when I install the 555.85 Game Ready Driver, I get the error:
“This NVIDIA graphics driver is not compatible with your device.”
I also tried other driver versions, but many are either too new or incompatible.
Any suggestions on which driver version is suitable for RTX 4050 Laptop to run Isaac Sim 4.5.0?
Or any workaround to fix the segmentation fault issue?
[Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INCOMPATIBLE_DRIVER
[Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
[Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
[Error] [omni.gpu_foundation_factory.plugin] Failed to create any GPU devices
[Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
libomni.kit.app.plugin.so!std::string::replace(...) + 0xaad3
libomni.kit.app.plugin.so!_init+0x899a
kit!_start+0x29
This NVIDIA graphics driver is not compatible with this version of Windows
