Isaac Sim 6.0.1: random SIGSEGV in libcarb.taskingplugin.so (make_fcontext) on RTX 4090
**Environment**
  • Isaac Sim: 6.0.1 official image (nvcr.io/nvidia/isaac-sim:6.0.1)
  • GPU: NVIDIA GeForce RTX 4090 (24 GB), single card (GPU 0) — host has 2× 4090 but the
    container is assigned GPU 0 only
  • Driver: 595.84 (CUDA 13.2)
  • CPU: Intel Xeon w7-2495X (24 cores / 48 threads); OS: Ubuntu host, Docker container
  • Mode: headless standalone via a self-written script (run_standalone.py, launched with
    ./python.sh, physics 100 Hz). Loads a Nova Carter rig + Rivermark scene, drives an RTX
    LiDAR + IMU, publishes ROS 2 topics for SLAM testing. NOT an official Isaac Sim script.
**Summary**
Isaac Sim crashes with a random SIGSEGV in libcarb.taskingplugin.so. Crash timing is
non-deterministic — from ~10 s after startup up to 30+ hours. 7 crashes recorded between
2026-07-23 and 2026-08-15. The crash always resolves to the same fiber-switch point
(make_fcontext), consistent with a use-after-free / double-free.
**Crash stack** (from carb.crashreporter-breakpad.plugin)
libgpu.foundation.plugin.so!std::map::operator[]()
libcarb.tasking.plugin.so!std::string::_M_dispose()
libcarb.tasking.plugin.so!std::string::resize()
libcarb.tasking.plugin.so!make_fcontext
terminating with exit code 139 (SIGSEGV)
**Crash history** (from /root/.nvidia-omniverse/logs/carb.crashreporter.log)
— dump sizes 620–740 KB, consistent with a single crash site:
# Time (UTC) dumpSize Upload
1 2026-07-23 05:37 666 KB Success
2 2026-07-23 09:31 — succeeded
3 2026-07-24 01:01 620 KB Success
4 2026-07-29 04:41 740 KB FailedButRetry
5 2026-08-07 13:00 708 KB Success
6 2026-08-15 01:51 659 KB Success
7 2026-08-15 02:15 644 KB Success
**Minidump crash IDs / upload UUIDs** (for lookup in the crash DB)
1f50340a-849c-48f0-3a810aa1-dfbc6c71 (upload: ae43eb0e-c6c5-4448-ac04-4d79303f5c7a)
8c21ee4e-50d5-41be-58064b85-9478c327 (upload: 0cc0f61b-b709-4890-9953-f88f9e90c38f)
3e247a34-978c-47d5-42a32dbe-c30fcd0c (upload: b9b03cf7-48b0-4ecc-a445-f97715a71e65)
74a23193-c215-4381-e148f889-f7dcedb8 (upload failed/retry)
e73f2081-c7aa-48a0-f373d5a8-34fbda9f (upload: cca2ae75-c6ed-4a7c-98d0-28633584eb8c)
50b5f999-39e1-403f-30c3f9b0-93aeff65
**Already ruled out**
  • NOT caused by material/asset UsdToMdl errors or MotionBVH warnings (cosmetic / expected).
  • NOT caused by multi-GPU / P2P (the container uses a single card, GPU 0).
**Related reports** (for reference only, not a root-cause claim)
Forum post 371957 (“Isaac Sim 5.1.0 crashes on startup … segfaulting in
librtx.scenedb.plugin.so”) has a stack that also contains
libcarb.tasking.plugin.so!make_fcontext, where NVIDIA confirmed the 5.1.0 crash was caused
by the 595.x driver branch. We note this only as a similar stack signature.
**Questions**
  1. Is this a known libcarb.tasking use-after-free in 6.0.1?
  2. Any fix or workaround to reduce crash frequency?
Hi there, and welcome to the community!
Since you are currently on driver version 595.84 and noted previous crash issues related to the 595.x driver branch, I highly recommend trying driver version 595.58.03 to see if it resolves the make_fcontext issue.
This specific driver is the officially recommended version for stability. You can find more details in the official documentation here:
Please let us know if the crashes persist after switching to this driver!
Thank you for your reply. I will show you the results when I try it.
Hello, @974811012. We haven’t received any updates from you regarding the results after switching to driver 595.58.03. Therefore, I’m closing this topic. If the crashes persist or you have new findings, please open a new topic and reference this one so we have full context. Good luck with your testing!
