I am running Isaac Sim 2022.2.0 inside a VM on an OVX server, using Teradici as a remote desktop solution. Working with my scene works only when using the Real-Time renderer. FPS is around 20-60.
As soon as I switch to path traced rendering, the viewport and the whole application is almost stuck, with only 0.2 FPS.
This is the output of nvidia-smi (we have a grid driver installed, as described in the Teradici docs):
testuser@rendering-ovx0-lin-dev-00:~$ nvidia-smi
Wed Mar 22 15:49:38 2023
| NVIDIA-SMI 525.85.05 Driver Version: 525.85.05 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA A40-24Q On | 00000000:02:00.0 Off | Off |
| N/A N/A P8 N/A / N/A | 0MiB / 24576MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
Thanks for any help.
Bruno
