Isaac2023 grid cloner's position offsets not working
While migrating to Isaac2023, I noticed that the cloning offsets are not working.
For example, running the clone_ants.py example with a z offset of 5m does not work and the ants are spawned at the ground level anyway.
An easy fix for me was to revert the grid_cloner.py script to the one of Isaac2022 and adding back the new copy_from_source input. This indeed solves the issue.
Didn’t have the time to go through the code though, so I don’t know where exactly the problem is with the new GridCloner.
As a reference, here’s the code I am using for the grid_cloner.py:
# Copyright (c) 2022-2023, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
from typing import List, Union
import numpy as np
import omni.usd
import torch
from omni.isaac.cloner import Cloner
from pxr import Gf, UsdGeom
class GridCloner(Cloner):
    """ This is a specialized Cloner class that will automatically generate clones in a grid fashion. """
    def __init__(self, spacing: float, num_per_row: int = -1):
        Args:
            spacing (float): Spacing between clones.
            num_per_row (int): Number of clones to place in a row. Defaults to sqrt(num_clones).
        self._spacing = spacing
        self._num_per_row = num_per_row
        Cloner.__init__(self)
    def clone(
        self,
        source_prim_path: str,
        prim_paths: List[str],
        position_offsets: np.ndarray = None,
        orientation_offsets: np.ndarray = None,
        replicate_physics: bool = False,
        base_env_path: str = None,
        root_path: str = None,
        copy_from_source: bool = False
        """ Creates clones in a grid fashion. Positions of clones are computed automatically.
        Args:
            source_prim_path (str): Path of source object.
            prim_paths (List[str]): List of destination paths.
            position_offsets (np.ndarray): Positions to be applied as local translations on top of computed clone position.
                                           Defaults to None, no offset will be applied.
            orientation_offsets (np.ndarray): Orientations to be applied as local rotations for each clone.
            replicate_physics (bool): Uses omni.physics replication. This will replicate physics properties directly for paths beginning with root_path and skip physics parsing for anything under the base_env_path.
            base_env_path (str): Path to namespace for all environments. Required if replicate_physics=True and define_base_env() not called.
            root_path (str): Prefix path for each environment. Required if replicate_physics=True and generate_paths() not called.
            copy_from_source: (bool): Setting this to False will inherit all clones from the source prim; any changes made to the source prim will be reflected in the clones.
                         Setting this to True will make copies of the source prim when creating new clones; changes to the source prim will not be reflected in clones. Defaults to False. Note that setting this to True will take longer to execute.
        Returns:
            positions (List): Computed positions of all clones.
        num_clones = len(prim_paths)
        self._num_per_row = int(np.sqrt(num_clones)) if self._num_per_row == -1 else self._num_per_row
        num_rows = np.ceil(num_clones / self._num_per_row)
        num_cols = np.ceil(num_clones / num_rows)
        row_offset = 0.5 * self._spacing * (num_rows - 1)
        col_offset = 0.5 * self._spacing * (num_cols - 1)
        positions = []
        orientations = []
        for i in range(num_clones):
            # compute transform
            row = i // num_cols
            col = i % num_cols
            x = row_offset - row * self._spacing
            y = col * self._spacing - col_offset
            up_axis = UsdGeom.GetStageUpAxis(stage)
            position = [x, y, 0] if up_axis == UsdGeom.Tokens.z else [x, 0, y]
            orientation = Gf.Quatd.GetIdentity()
            if position_offsets is not None:
                translation = position_offsets[i] + position
            else:
            if orientation_offsets is not None:
                orientation = (
                    Gf.Quatd(orientation_offsets[i][0].item(), Gf.Vec3d(orientation_offsets[i][1:].tolist()))
                    * orientation
            else:
                orientation = [
                    orientation.GetReal(),
                    orientation.GetImaginary()[0],
                    orientation.GetImaginary()[1],
                    orientation.GetImaginary()[2],
            positions.append(translation)
            orientations.append(orientation)
        super().clone(
            source_prim_path=source_prim_path,
            prim_paths=prim_paths,
            positions=positions,
            orientations=orientations,
            replicate_physics=replicate_physics,
            base_env_path=base_env_path,
            root_path=root_path,
            copy_from_source=copy_from_source,
        return positions
Hi there, thanks for reporting the issue. We will work on a fix for this.
