I have a 32 GB sd card where my original os was installed, then added 500 GB SSD. Copied rootfs from sd card to SSD to make SSD my root, It worked perfectly fine, but when I unmount my sd card and mount it back, unable to boot my nx. When I try to boot, I get Nvidia logo and then it gets frozen, connects to wifi , keyboard, mouse gets connected and able to operate in terminal mode using clt+alt+f4. It doesn’t recognize my sd card, it is shown in lsblk without any mounted on path.
Please help me understand what went wrong and how to fix this.
With just the sd card, removing the SSD, works perfect boot normally. But when I put my SSD to the M2 slot and restart, it gets froze in nvidia logo.
NOTE: Not sure the exact trigger for this behavior, but this started after I eject my sd card and put it back and reboot.
lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
mtdblock0 31:0 0 32M 0 disk
mmcblk0 179:0 0 29.8G 0 disk
├─mmcblk0p1 179:1 0 29.5G 0 part
├─mmcblk0p2 179:2 0 64M 0 part
├─mmcblk0p3 179:3 0 64M 0 part
├─mmcblk0p4 179:4 0 448K 0 part
├─mmcblk0p5 179:5 0 448K 0 part
├─mmcblk0p6 179:6 0 63M 0 part
├─mmcblk0p7 179:7 0 512K 0 part
├─mmcblk0p8 179:8 0 256K 0 part
├─mmcblk0p9 179:9 0 256K 0 part
├─mmcblk0p10 179:10 0 100M 0 part
└─mmcblk0p11 179:11 0 18K 0 part
zram0 252:0 0 1.9G 0 disk [SWAP]
zram1 252:1 0 1.9G 0 disk [SWAP]
nvme0n1 259:0 0 465.8G 0 disk
└─nvme0n1p1 259:1 0 456.4G 0 part /
unable to boot my nx. When I try to boot, I get Nvidia logo and then it gets frozen, connects to wifi , keyboard, mouse gets connected and able to operate in terminal mode using clt+alt+f4. It doesn’t recognize my sd card, it is show in lsblk without any mounted on path.
I think it is not"unable to boot". More precisely, it is just not able to run the desktop manager. If OS is not up, then no terminal will be there for you.
Besides the boot up log from uart, please also share me the dmesg and /var/log/Xorg.0.log.
I followed the video you shared to connect the TTL to usb converter cable.
When I run sudo minicom and power on the jetson nx, it doesnt show any log in the terminal. Can you please help me to understand where is it going wrong.
According to your log, you are using jetpack4.5.x which does not support nvme in cboot yet. Thus, both kernel and rootfs in this log are booting from sdcard.
Actually, I see no error from every of log you shared.
What is the monitor resolution you are using here? According to the kernel log, it looks like not a common one.
Can you check if your “Xorg.0.log” really gets updated in each reboot? I mean making sure you are not sharing a log that was generated long time ago.
Yes the log file is getting updated, earlier the uart log I sent was without any hdmi to monitor. Attaching the new uart file with monitor attached and the Xorg file. uart_log_new (91.6 KB) Xorg.0.log (13.1 KB)
I see the nvidia icon, wifi gets connected and then a error window pops up saying " System program problem detected, Do you wnat to report the problem now?" and after closing the popup the window just shows the default nvidia icon, doesnt take me to the home page.
I followed instructions from below github link to copy my rootfs from sd card to SSD
Earlier it use to show in df -h as external memory 32 GB,
lsblk shows some info in mmcblk0p1,
lsblk output:
