**• Hardware Platform (Jetson / GPU): Jetson Nano
**• DeepStream Version: 6.0
When running: sudo apt-cache show nvidia-jetpack, I get the following message:
Package: nvidia-jetpack
Version: 4.5.1-b17
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.5.1-b17), nvidia-opencv (= 4.5.1-b17), nvidia-cudnn8 (= 4.5.1-b17), nvidia-tensorrt (= 4.5.1-b17), nvidia-visionworks (= 4.5.1-b17), nvidia-container (= 4.5.1-b17), nvidia-vpi (= 4.5.1-b17), nvidia-l4t-jetson-multimedia-api (>> 32.5-0), nvidia-l4t-jetson-multimedia-api (<< 32.6-0)
Homepage: Autonomous Machines | NVIDIA Developer
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.5.1-b17_arm64.deb
SHA256: 13c10e9a53ec51c261ce188d626966dfca27f26b2ed94ba700147c1ba3e35399
SHA1: 81047a7779241bbf16763dbd1c4c12cf8c9d0496
MD5sum: 54916439514f39af5234b3a43e329910
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.5-b129
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.5-b129), nvidia-opencv (= 4.5-b129), nvidia-cudnn8 (= 4.5-b129), nvidia-tensorrt (= 4.5-b129), nvidia-visionworks (= 4.5-b129), nvidia-container (= 4.5-b129), nvidia-vpi (= 4.5-b129), nvidia-l4t-jetson-multimedia-api (>> 32.5-0), nvidia-l4t-jetson-multimedia-api (<< 32.6-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.5-b129_arm64.deb
SHA256: 9ee354a66d932a3fbb244c926f333143a845c627c6981d108e01df2958ac462c
SHA1: 0e07f27c6fb9e34a70c69ae1150d1e578e938089
MD5sum: a551bbc8ff653c8983ce1804082bbcab
I have already made the deepstream-occupancy-analytics on deepstream 5.1 and it worked fine, I cloned the same application on a different jetson with deepstream 6.0, but I get the following error:
** ERROR: <create_osd_bin:58>: Failed to create ‘nvosd0’
** ERROR: <create_osd_bin:100>: create_osd_bin failed
** ERROR: <create_processing_instance:815>: create_processing_instance failed
** ERROR: <create_pipeline:1323>: create_pipeline failed
** ERROR: main:1041: Failed to create pipeline
Quitting
App run failed
Any idea what this issue is referring to?
