axnet
June 21, 2023, 9:17pm
1
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
I have installed deepstream pyhton apps using the following link GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications . when trying (Test 1) from python sample application the below error is generated
In the command file i have used the file name
how to solve this issue and how to make sure bindings are correctly installed
The version of your Jetpack is 5.1 and the corresponding DeepStream should be 6.2, but in the screenshot the version is 6.1, can you double check the version first?
The log shows “unable to create NvStreammux and pgie”, seems Deepstream is not well installed.
Should be your DeepStream python binding isn’t installed correctly.
Try the README in binding s folder
axnet
June 24, 2023, 10:18am
6
I have followed exact steps but same issue
Maybe Deepstream is not installed successfully
Can you try this command first ?
deepstream-app --version-all
Try reinstall DeepStream SDK by this reference documents
