**• Hardware Platform (Jetson / GPU) - Tesla T4 ** • DeepStream Version - Deepstream-6.2 • JetPack Version (valid for Jetson only) • TensorRT Version - 8.5.2.2nvidia- • NVIDIA GPU Driver Version (valid for GPU only) - 525.85.12 • Issue Type( questions, new requirements, bugs) - Query • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I am trying to run the deepstream-test1 sample example present at deepstream_python_apps/apps/deepstream-test1 at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub.
I followed the README file and ran the command “python3 ./deepstream_test_1.py …/…/…/samples/streams/sample_1080p_h264.h264” and got the error “ModuleNotFoundError: No module named ‘pyds’”. My Python version is 3.8.10 and my Deepstream version is 6.2. Do I need to explicitly install all the modules expected by the example or they all be found somewhere? Am I missing something?
I will try the example once with the wheel file for DS62.
On a different note, I also tried running the C++ version of the example (Came pre-installed with the docker I downloaded). When I run the example, I do see the inference getting printed on the console but not as bounding boxes on the video.
When I run the example, I do see the video trying to come up but also closing immediately. I also observed the following error in the running logs -
0:00:04.031153770 507 0x55d8e24304c0 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:04.031170288 507 0x55d8e24304c0 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(2369): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Can you please suggest what am I missing?
Are you running the sample in docker ?
run this command
xhost +
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.2 nvcr.io/nvidia/deepstream:6.2-devel
Allow external applications to connect to the host’s X display
here is same refer information about DeepStream Docker
