Issue Using Enterprise Wifi on TX2
My university uses MSCHAPV2 / Peap authentication over wifi, and I cannot seem to get it setup properly. Everything is set to the correct settings, however, whenever I ask it to connect, it boots me back to putting my username and password in again.
I have gotten this issue solved with other Linux devices, from Pis to desktops, but this seems to be giving me problems.
Any help would be appreciated!
duganwdobbs,
Does this happen only to Peap auth AP? Any log for the disconnection?
It happens only for PEAP, and I am unsure of where to find the logs. I did a apt-update, apt-upgrade and the WIFI started working on the enterprise wifi, then I proceeded to flash the board with Jetpack3.2. The wifi is back to rejecting the enterprise wifi logins.
If you could let me know what logs you need I’d greatly appreciate it, downloading things through phone tethering is slow!
duganwdobbs,
I believe you could see it by using “dmesg”. If you need verbose, below method could be used and more log can be seen in dmesg.
sudo -s
 echo 0x10801 > /sys/module/bcmdhd/parameters/dhd_msg_level
 echo 120 > /sys/module/bcmdhd/parameters/dhd_console_ms
@duganwdobbs: Does University MSCHAPV2 / Peap authentication use a CA certificate?
There was reported a bug in network manager: https://bugs.launchpad.net/ubuntu/+source/network-manager-applet/+bug/1104476 . Some workarounds were suggested : https://askubuntu.com/questions/279762/how-to-connect-to-wpa2-peap-mschapv2-enterprise-wifi-networks-that-dont-use-a-c
However, I did not deal with the issue.
I lack a Peap auth wifi in office and cannot verify this issue.
duganwdobbs,
Please try the suggestion from Andrey1984 first. Thanks!
duganwdobbs,
Any update?
Apologies, classes have been hectic and I haven’t had much time to work with the board.
For the system-ca-cert=true workaround, my config never had that line.
For writing the whole connection profile in /etc/NetworkManager/system-connections, I tried this and it didn’t work
For modifying/changing the WPA-Supplicant, as per here: https://wireless.wiki.kernel.org/en/users/Documentation/wpa_supplicant , this did not work either.
I will be pulling the dmesg onto a usb here in a minute.
Does University MSCHAPV2 / Peap authentication use a CA certificate, or the method you are using doesn’t utilize a CA certificate?
[ 2.666954] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.667123] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 2.667125] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 2.667164] igb: Intel® Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.667167] igb: Copyright © 2007-2014 Intel Corporation.
[ 2.668232] PPP generic driver version 2.4.2
[ 2.668381] PPP BSD Compression module registered
[ 2.668417] PPP Deflate Compression module registered
[ 2.668440] PPP MPPE Compression module registered
[ 2.668453] NET: Registered protocol family 24
[ 2.668507] usbcore: registered new interface driver r8152
[ 2.668541] usbcore: registered new interface driver asix
[ 2.668572] usbcore: registered new interface driver ax88179_178a
[ 2.668603] usbcore: registered new interface driver cdc_ether
[ 2.668638] usbcore: registered new interface driver smsc75xx
[ 2.668664] usbcore: registered new interface driver net1080
[ 2.668691] usbcore: registered new interface driver cdc_subset
[ 2.668718] usbcore: registered new interface driver zaurus
[ 2.668769] usbcore: registered new interface driver cdc_ncm
[ 2.669061] Wake76 for irq=199
[ 2.669064] Wake77 for irq=199
[ 2.669067] Wake78 for irq=199
[ 2.669068] Wake79 for irq=199
[ 2.669070] Wake80 for irq=199
[ 2.669072] Wake81 for irq=199
[ 2.669073] Wake82 for irq=199
[ 2.669135] tegra-xotg xotg: usb2 phy is not available yet
[ 2.669793] usbcore: registered new interface driver cdc_acm
[ 2.669795] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.669835] usbcore: registered new interface driver usb-storage
[ 2.669899] usbcore: registered new interface driver usbserial
[ 2.669923] usbcore: registered new interface driver cp210x
[ 2.669942] usbserial: USB Serial support registered for cp210x
[ 2.669965] usbcore: registered new interface driver ftdi_sio
[ 2.669983] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.670008] usbcore: registered new interface driver option
[ 2.670025] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.670048] usbcore: registered new interface driver pl2303
[ 2.670067] usbserial: USB Serial support registered for pl2303
[ 2.670251] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.671255] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c c8 5
[ 2.671841] libphy: dwc_phy: probed
[ 2.672793] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.735504] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.804136] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.806229] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.806244] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.806390] i2c /dev entries driver
[ 2.807145] [OV5693]: probing v4l2 sensor.
[ 2.982363] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.297781] tegradc 15210000.nvdisplay: fb registered
[ 3.304507] PD DISP0 index2 UP
[ 3.309666] PD DISP1 index3 UP
[ 3.314191] PD DISP2 index4 UP
[ 3.327783] Parent Clock set for DC plld2
[ 3.334219] edid invalid
[ 3.383516] edid invalid
[ 3.387344] edid invalid
[ 3.391161] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:prod_c_150M
[ 3.546548] tegradc 15210000.nvdisplay: blank - normal
[ 3.550308] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.608996] PD DISP2 index4 DOWN
[ 3.611411] PD DISP1 index3 DOWN
[ 3.612055] PD DISP0 index2 DOWN
[ 3.640784] tegradc 15210000.nvdisplay: unblank
[ 3.640903] PD DISP0 index2 UP
[ 3.647136] PD DISP1 index3 UP
[ 3.647701] PD DISP2 index4 UP
[ 3.663097] Parent Clock set for DC plld2
[ 3.665981] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 3.680899] random: nonblocking pool is initialized
[ 3.682407] gspca_main: v2.14.0 registered
[ 3.682465] usbcore: registered new interface driver gspca_zc3xx
[ 3.682790] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.684734] FAN dev name: pwm-fan
[ 3.684782] FAN:gpio request success.
[ 3.684788] FAN: can’t find tach_gpio
[ 3.684814] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.684980] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.684984] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.685283] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.685287] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.685290] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.685293] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.685296] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.685299] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.685301] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.685304] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.685307] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.685310] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.686034] device-mapper: uevent: version 1.0.3
[ 3.686221] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.686622] sdhci: Secure Digital Host Controller Interface driver
[ 3.686623] sdhci: Copyright© Pierre Ossman
[ 3.686628] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.686913] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.687192] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.687429] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.688581] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.688701] hidraw: raw HID events driver © Jiri Kosina
[ 3.690248] usbcore: registered new interface driver usbhid
[ 3.690249] usbhid: USB HID core driver
[ 3.695054] nvadsp 2993000.adsp: in probe()…
[ 3.696966] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.696992] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.697176] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.697889] Denver: backdoor interface is NOT available.
[ 3.699580] coresight-tmc 8030000.etf: TMC initialized
[ 3.700662] coresight-tmc 8050000.etr: TMC initialized
[ 3.701003] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.701468] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.701870] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.702266] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.702703] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.703301] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.703827] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.704353] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.704874] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.704899] Module initialized successfully
[ 3.708124] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.709299] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.709483] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.709797] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.709839] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.709876] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.709916] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.709952] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.709988] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.710025] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.710150] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.710152] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.710757] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.710759] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.710761] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.710764] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.710766] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.710769] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.710771] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.710796] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.714303] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.715009] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.715118] camchar: rtcpu character device driver loaded
[ 3.718384] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.718611] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.718699] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.719030] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.719055] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.719081] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.719104] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.719127] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.719150] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.719174] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.719197] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.719219] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.719240] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.719265] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.719287] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.719310] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.719332] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.719358] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.719404] **** A57 ECC: Enabled
[ 3.719406] tegra18_a57_serr_init: on CPU 3 a A57 Core
[ 3.719547] parse_throttle_dt_data: Num cap clks = 4
[ 3.719551] parse_throttle_dt_data: clk=mcpu type=1
[ 3.719552] parse_throttle_dt_data: clk=bcpu type=2
[ 3.719558] parse_throttle_dt_data: clk=gpu type=4
[ 3.719559] parse_throttle_dt_data: clk=emc type=3
[ 3.719998] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.720078] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.722351] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.722551] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.722564] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.722794] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.722887] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.724933] tegra-se-nvhost 15810000.se: initialized
[ 3.725411] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.725738] tegra-se-nvhost 15820000.se: initialized
[ 3.727435] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.727754] tegra-se-nvhost 15830000.se: initialized
[ 3.727859] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.728142] tegra-se-nvhost 15840000.se: initialized
[ 3.728498] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.732199] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.735509] cpufreq: platform driver Initialization: pass
[ 3.735643] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.735691] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.735862] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.735868] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.735902] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab495
[ 3.735905] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.737033] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.737552] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.738044] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.738384] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.739880] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.739991] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.740843] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.740846] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.743456] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.744001] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.744236] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.744534] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.744796] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.745093] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.745097] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.745098] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.755687] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.755687] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.755808] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.756391] OPE platform probe
[ 3.756464] OPE platform probe successful
[ 3.758365] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.758620] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.758669] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.758761] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.758780] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.759254] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.792363] mmc0: MAN_BKOPS_EN bit is not set
[ 3.798652] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.799609] mmc0: Skipping tuning since strobe enabled
[ 3.807070] mmc0: periodic cache flush enabled
[ 3.807077] mmc0: new HS400 MMC card at address 0001
[ 3.811396] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.811516] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.811635] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.811754] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.813546] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.820421] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.820577] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.820721] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.820866] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.821008] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.821125] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.821223] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.821316] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.821410] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.821508] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.821624] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.821720] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.821825] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.821946] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.822044] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.822144] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.822246] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.822385] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.822484] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.822588] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.826951] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.827048] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.827086] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.827118] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.850736] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.865958] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.866732] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.866735] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.867483] GACT probability NOT on
[ 3.867494] Mirror/redirect action on
[ 3.867506] u32 classifier
[ 3.867507] Actions configured
[ 3.867543] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.868208] IPVS: Registered protocols ()
[ 3.868241] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.868316] IPVS: Creating netns size=1424 id=0
[ 3.868419] IPVS: ipvs loaded.
[ 3.868425] IPVS: [rr] scheduler registered.
[ 3.868499] ipip: IPv4 over IPv4 tunneling driver
[ 3.868950] Initializing XFRM netlink socket
[ 3.869317] NET: Registered protocol family 10
[ 3.870017] ip6_tables: © 2000-2006 Netfilter Core Team
[ 3.870083] NET: Registered protocol family 17
[ 3.870096] NET: Registered protocol family 15
[ 3.870125] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.870131] 8021q: 802.1Q VLAN Support v1.8
[ 3.870461] Registered cp15_barrier emulation handler
[ 3.870474] Registered setend emulation handler
[ 3.872520] registered taskstats version 1
[ 3.876093] isp 15600000.isp: initialized
[ 3.880208] nvcsi 150c0000.nvcsi: initialized
[ 3.881315] Wake76 for irq=199
[ 3.881316] Wake77 for irq=199
[ 3.881317] Wake78 for irq=199
[ 3.881317] Wake79 for irq=199
[ 3.881318] Wake80 for irq=199
[ 3.881319] Wake81 for irq=199
[ 3.881319] Wake82 for irq=199
[ 3.881632] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.881634] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 3.906626] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.906794] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.906796] xhci-tegra 3530000.xhci: Falling back to user helper
[ 3.907296] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.908071] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.908793] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 3.908828] tegra-xotg xotg: update_id_state: ID grounded
[ 3.908832] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 3.908847] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 3.910544] tegra-xotg xotg: otg: gadget gadget registered
[ 3.910545] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 3.910547] tegra-xotg xotg: otg: host not registered yet
[ 3.910548] tegra-xotg xotg: otg: start OTG finite state machine
[ 3.910588] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.910620] tegra-xotg xotg: FSM: can’t move to a_idle, host isn’t ready
[ 3.911058] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.911647] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.946233] tegra_rtc c2a0000.rtc: setting system clock to 2018-04-14 20:00:43 UTC (1523736043)
[ 3.976119] bpmp: mounted debugfs mirror
[ 3.976617] [dram-timers] DRAM derating cdev registered.
[ 3.981110] spmic-ldo0: disabling
[ 3.981296] spmic-ldo1: disabling
[ 3.981446] en-vdd-cam: disabling
[ 3.981448] vdd-usb0-5v: disabling
[ 3.981450] vdd-usb1-5v: disabling
[ 3.981453] en-vdd-disp-3v3: disabling
[ 3.981455] en-mdm-pwr-3v7: disabling
[ 3.981456] en-vdd-disp-1v8: disabling
[ 3.981458] en-vdd-cam-hv-2v8: disabling
[ 3.981459] en-vdd-cam-1v2: disabling
[ 3.981461] vdd-fan: disabling
[ 3.981463] vdd-3v3: disabling
[ 3.981465] en-vdd-vcm-2v8: disabling
[ 3.981466] vdd-usb2-5v: disabling
[ 3.981467] vdd-sys-bl: disabling
[ 3.981469] en-vdd-sys: disabling
[ 3.989489] ALSA device list:
[ 3.989493] #0: tegra-hda at 0x3518000 irq 400
[ 3.989495] #1: tegra-snd-t186ref-mobile-rt565x
[ 3.990841] tegra-vi4 15700000.vi: initialized
[ 3.992004] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 3.992007] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 4.048443] mmc1 tuning done saved tap delay=63
[ 4.048444] mmc1: hw tuning done …
[ 4.048450] mmc1: tuning_window[0]: 0xffffffff
[ 4.048455] mmc1: tuning_window[1]: 0xfffff9ff
[ 4.048460] mmc1: tuning_window[2]: 0xff1fffff
[ 4.048464] mmc1: tuning_window[3]: 0x7fffffff
[ 4.048468] mmc1: tuning_window[4]: 0x0
[ 4.048473] mmc1: tuning_window[5]: 0x0
[ 4.048499] mmc1: tuning_window[6]: 0x0
[ 4.048503] mmc1: tuning_window[7]: 0x0
[ 4.048506] sdhci: Tap value: 63 | Trim value: 5
[ 4.048509] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.054049] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.054092] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 6.655018] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.659900] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.659915] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.660773] devtmpfs: mounted
[ 6.661080] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc001256000)
[ 6.661103] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc00126e000)
[ 6.669192] btb inv war enabled
[ 6.727747] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.747915] systemd[1]: Detected architecture arm64.
[ 6.765111] systemd[1]: Set hostname to .
[ 6.884397] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.895840] systemd[1]: Created slice System Slice.
[ 6.904372] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.914275] systemd[1]: Listening on Syslog Socket.
[ 6.922896] systemd[1]: Listening on Journal Audit Socket.
[ 6.932053] systemd[1]: Reached target Swap.
[ 6.941418] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.950136] systemd[1]: Reached target Encrypted Volumes.
[ 6.958217] systemd[1]: Reached target User and Group Name Lookups.
[ 6.967165] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.976744] systemd[1]: Listening on udev Control Socket.
[ 6.985106] systemd[1]: Created slice User and Session Slice.
[ 6.993505] systemd[1]: Reached target Slices.
[ 7.000676] systemd[1]: Listening on udev Kernel Socket.
[ 7.008824] systemd[1]: Listening on Journal Socket.
[ 7.018278] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.029690] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.031110] systemd[1]: Started Braille Device Support.
[ 7.048697] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 7.063542] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.073840] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.083376] systemd[1]: Reached target Remote File Systems.
[ 7.097214] systemd[1]: Starting Load Kernel Modules…
[ 7.107672] systemd[1]: Starting Set console keymap…
[ 7.118099] systemd[1]: Mounting Debug File System…
[ 7.128249] systemd[1]: Starting Journal Service…
[ 7.140310] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.150050] systemd[1]: Mounted Debug File System.
[ 7.158950] systemd[1]: Started Remount Root and Kernel File Systems.
[ 7.174186] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 7.187736] systemd[1]: Started Load Kernel Modules.
[ 7.197043] systemd[1]: Started Set console keymap.
[ 7.206043] systemd[1]: Started Journal Service.
[ 7.347815] systemd-journald[290]: Received request to flush runtime journal from PID 1
[ 7.537917] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 7.555197] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 7.569312] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 7.581718] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 7.604366] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 7.725333] dhd_module_init in
[ 7.734380] tegra_net_perf_init: cannot get wifi sclk
[ 7.743643] found wifi platform device bcmdhd_wlan
[ 7.762550] wifi_platform_get_country_code_map: could not get country_code_map
[ 7.772859] wifi_plat_dev_drv_probe:platform country code map is not available
[ 7.772872] Power-up adapter ‘DHD generic adapter’
[ 7.772879] wifi_platform_set_power = 1
[ 7.974356] wifi_platform_bus_enumerate device present 1
[ 8.003949] wifi_platform_bus_enumerate device present 0
[ 8.019875] F1 signature read @0x18000000=0x17214354
[ 8.047298] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.068364] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.089992] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.104057] wifi_platform_prealloc: failed to alloc static mem section 7
[ 8.136846] wifi_platform_get_mac_addr
[ 8.154468] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 8.168916] wl_create_event_handler(): thread:wl_event_handler:2e7 started
[ 8.188250] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e1141a70
[ 8.215897] dhd_attach(): thread:dhd_watchdog_thread:2f1 started
[ 8.233162] dhd_attach(): thread:dhd_dpc:319 started
[ 8.275318] dhd_attach(): thread:dhd_rxf:321 started
[ 8.275324] dhd_deferred_work_init: work queue initialized
[ 8.276888] Dongle Host Driver, version 1.201.82 ®
Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:46:20
[ 8.277388] tegra_sysfs_register
[ 8.277417] Register interface [wlan0] MAC: 00:04:4b:8c:c8:03
[ 8.277420] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.277513] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 63
[ 8.278583] wifi_platform_set_power = 0
[ 8.482757] using random self ethernet address
[ 8.502451] using random host ethernet address
[ 8.528385] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.539516] Mass Storage Function, version: 2009/09/11
[ 8.548269] LUN: removable file: (no medium)
[ 8.561882] using random self ethernet address
[ 8.569552] using random host ethernet address
[ 8.586387] usb0: HOST MAC 26:5e:ec:1a:d1:03
[ 8.593278] usb0: MAC 7e:fe:88:8d:15:16
[ 8.601100] usb1: HOST MAC 6e:f6:7a:0a:bf:01
[ 8.601163] usb1: MAC 3a:c3:73:97:b6:24
[ 8.601181] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.602237] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.602252] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.602272] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.602874] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.602884] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.603674] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.603687] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.604186] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.633395] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 8.642466] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.642483] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 8.643296] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 8.643318] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 8.643503] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.643506] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.643508] usb usb1: Product: xHCI Host Controller
[ 8.643510] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.643511] usb usb1: SerialNumber: 3530000.xhci
[ 8.651187] hub 1-0:1.0: USB hub found
[ 8.651215] hub 1-0:1.0: 4 ports detected
[ 8.678596] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.678603] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 8.678832] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.678835] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.678837] usb usb2: Product: xHCI Host Controller
[ 8.678839] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.678840] usb usb2: SerialNumber: 3530000.xhci
[ 8.679180] hub 2-0:1.0: USB hub found
[ 8.679203] hub 2-0:1.0: 3 ports detected
[ 8.679580] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 8.682026] device usb0 entered promiscuous mode
[ 8.685797] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.690532] device usb1 entered promiscuous mode
[ 8.690566] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 8.694618] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 8.694622] l4tbr0: port 2(usb1) entered forwarding state
[ 8.694634] l4tbr0: port 2(usb1) entered forwarding state
[ 8.950329] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.960688] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 8.970352] usb 1-2: new high-speed USB device number 2 using xhci-tegra
[ 8.994761] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 9.019094] usb 2-1: New USB device found, idVendor=0424, idProduct=5537
[ 9.027671] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 9.027674] usb 2-1: Product: USB5537
[ 9.027676] usb 2-1: Manufacturer: SMSC
[ 9.028299] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 9.029729] hub 2-1:1.0: USB hub found
[ 9.029800] hub 2-1:1.0: 7 ports detected
[ 9.110847] usb 1-2: New USB device found, idVendor=0424, idProduct=2137
[ 9.119383] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.119385] usb 1-2: Product: USB2137
[ 9.119387] usb 1-2: Manufacturer: SMSC
[ 9.120167] hub 1-2:1.0: USB hub found
[ 9.120240] hub 1-2:1.0: 7 ports detected
[ 9.288528] IPVS: Creating netns size=1424 id=1
[ 9.299015] usb 2-1.1: new SuperSpeed USB device number 3 using xhci-tegra
[ 9.323917] usb 2-1.1: New USB device found, idVendor=0424, idProduct=5534
[ 9.333057] usb 2-1.1: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 9.333059] usb 2-1.1: Product: USB5534
[ 9.333061] usb 2-1.1: Manufacturer: SMSC
[ 9.335281] hub 2-1.1:1.0: USB hub found
[ 9.335600] hub 2-1.1:1.0: 4 ports detected
[ 9.362598] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.365146] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.372361] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.406383] usb 1-2.1: new high-speed USB device number 3 using xhci-tegra
[ 9.406980] usb 2-1.2: new SuperSpeed USB device number 4 using xhci-tegra
[ 9.414891] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.414969]
[ 9.414971] wl_android_wifi_on in
[ 9.414973] wifi_platform_set_power = 1
[ 9.423653] usb 2-1.2: New USB device found, idVendor=17e9, idProduct=4312
[ 9.423656] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.423658] usb 2-1.2: Product: DELL S2340T USB
[ 9.423660] usb 2-1.2: Manufacturer: DisplayLink
[ 9.423662] usb 2-1.2: SerialNumber: 000008
[ 9.424334] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 9.455571] cdc_ncm 2-1.2:1.5: MAC-Address: 00:0f:9d:07:b7:ee
[ 9.455575] cdc_ncm 2-1.2:1.5: setting rx_max = 16384
[ 9.455722] cdc_ncm 2-1.2:1.5: setting tx_max = 16384
[ 9.511000] usb 1-2.1: New USB device found, idVendor=0424, idProduct=2134
[ 9.511006] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.511009] usb 1-2.1: Product: USB2134
[ 9.511013] usb 1-2.1: Manufacturer: SMSC
[ 9.512172] hub 1-2.1:1.0: USB hub found
[ 9.512326] hub 1-2.1:1.0: 4 ports detected
[ 9.524955] gk20a 17000000.gp10b: railgate is disabled.
[ 9.586353] usb 1-2.6: new full-speed USB device number 4 using xhci-tegra
[ 9.646803] tegradc 15210000.nvdisplay: blank - powerdown
[ 9.686978] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 9.697148] usb 1-2.6: New USB device found, idVendor=0596, idProduct=0524
[ 9.697152] usb 1-2.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.697156] usb 1-2.6: Product: 3M MicroTouch USB controller
[ 9.697159] usb 1-2.6: Manufacturer: 3M
[ 9.702842] input: 3M 3M MicroTouch USB controller as /devices/3530000.xhci/usb1/1-2/1-2.6/1-2.6:1.0/0003:0596:0524.0001/input/input4
[ 9.703020] hid-multitouch 0003:0596:0524.0001: input,hidraw0: USB HID v1.10 Pointer [3M 3M MicroTouch USB controller] on usb-3530000.xhci-2.6/input0
[ 9.706824] PD DISP2 index4 DOWN
[ 9.706921] PD DISP1 index3 DOWN
[ 9.707003] PD DISP0 index2 DOWN
[ 9.766558] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.778403] usb 1-2.7: new high-speed USB device number 5 using xhci-tegra
[ 9.791618] tegradc 15210000.nvdisplay: unblank
[ 9.791637] PD DISP0 index2 UP
[ 9.792889] PD DISP1 index3 UP
[ 9.793003] PD DISP2 index4 UP
[ 9.794814] Parent Clock set for DC plld2
[ 9.796496] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 9.819640] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 63
[ 9.820159] F1 signature read @0x18000000=0x17214354
[ 9.824369] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.824962] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.891011] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.933321] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.933735] Enabling wake69
[ 9.934675] wifi_platform_get_mac_addr
[ 9.937028] Firmware up: op_mode=0x0005, MAC=00:04:4b:8c:c8:03
[ 9.944667] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.951033] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-e35dbe99
[ 9.954345] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.954381] usb 1-2.1.1: new low-speed USB device number 6 using xhci-tegra
[ 9.954651] tegra_sysfs_on
[ 9.974076] usb 1-2.7: New USB device found, idVendor=0bda, idProduct=570a
[ 9.974092] usb 1-2.7: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 9.974103] usb 1-2.7: Product: DELL S2340T Webcam
[ 9.974114] usb 1-2.7: Manufacturer: 56.18006.48131P04Y
[ 9.974122] usb 1-2.7: SerialNumber: 201209030001
[ 10.011122] cdc_ncm 2-1.2:1.5 usb2: register ‘cdc_ncm’ at usb-3530000.xhci-1.2, CDC NCM, 00:0f:9d:07:b7:ee
[ 10.011670] l4tbr0: port 2(usb1) entered disabled state
[ 10.026434] cfg80211: World regulatory domain updated:
[ 10.026437] cfg80211: DFS Master region: unset
[ 10.026437] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 10.026441] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.026443] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.026444] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.026446] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 10.026448] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 10.026450] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 10.026452] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.026453] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 10.062610] usb 1-2.1.1: New USB device found, idVendor=04b4, idProduct=0033
[ 10.062613] usb 1-2.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 10.062837] usb 1-2.1.1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 10.068484] input: HID 04b4:0033 as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.0/0003:04B4:0033.0002/input/input5
[ 10.068717] hid-generic 0003:04B4:0033.0002: input,hidraw1: USB HID v1.00 Mouse [HID 04b4:0033] on usb-3530000.xhci-2.1.1/input0
[ 10.075293] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 10.086221] WLC_E_IF: NO_IF set, event Ignored
[ 10.154366] usb 1-2.1.2: new low-speed USB device number 7 using xhci-tegra
[ 10.172390] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 10.174351] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 10.174358] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 10.175710] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 10.265031] usb 1-2.1.2: New USB device found, idVendor=0e6a, idProduct=02c1
[ 10.265037] usb 1-2.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.265040] usb 1-2.1.2: Product: Gaming KB
[ 10.265044] usb 1-2.1.2: Manufacturer: Gaming KB
[ 10.265443] usb 1-2.1.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 10.265487] usb 1-2.1.2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 10.270118] input: Gaming KB Gaming KB as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1.2/1-2.1.2:1.0/0003:0E6A:02C1.0003/input/input6
[ 10.323299] hid-generic 0003:0E6A:02C1.0003: input,hidraw2: USB HID v1.11 Keyboard [Gaming KB Gaming KB] on usb-3530000.xhci-2.1.2/input0
[ 10.347488] input: Gaming KB Gaming KB as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1.2/1-2.1.2:1.1/0003:0E6A:02C1.0004/input/input7
[ 10.403054] hid-generic 0003:0E6A:02C1.0004: input,hidraw3: USB HID v1.11 Keyboard [Gaming KB Gaming KB] on usb-3530000.xhci-2.1.2/input1
[ 10.466821] uvcvideo: Found UVC 1.00 device DELL S2340T Webcam (0bda:570a)
[ 10.467654] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[ 10.468103] uvcvideo: Failed to query (129) UVC probe control : -71 (exp. 26).
[ 10.468105] uvcvideo: Failed to initialize the device (-5).
[ 10.468294] usbcore: registered new interface driver uvcvideo
[ 10.468295] USB Video Class driver (1.1.1)
[ 10.489467] IPv6: ADDRCONF(NETDEV_UP): usb2: link is not ready
[ 10.489596] IPv6: ADDRCONF(NETDEV_UP): usb2: link is not ready
[ 10.510623] usb 2-1.2: Warning! Unlikely big volume range (=511), cval->res is probably wrong.
[ 10.510628] usb 2-1.2: [16] FU [DELL S2340T Audio Playback Volume] ch = 6, val = -8176/0/16
[ 10.511535] usb 2-1.2: Warning! Unlikely big volume range (=767), cval->res is probably wrong.
[ 10.511538] usb 2-1.2: [13] FU [Mic Capture Volume] ch = 2, val = -4592/7680/16
[ 10.515556] usb 1-2.7: 3:1: cannot set freq 22050 to ep 0x82
[ 10.517598] usb 1-2.7: 3:2: cannot set freq 32000 to ep 0x82
[ 10.519623] usb 1-2.7: 3:3: cannot set freq 48000 to ep 0x82
[ 10.521652] usb 1-2.7: 3:4: cannot set freq 48000 to ep 0x82
[ 10.523696] usb 1-2.7: 3:5: cannot set freq 96000 to ep 0x82
[ 10.525719] usb 1-2.7: 3:6: cannot set freq 44100 to ep 0x82
[ 10.527771] usb 1-2.7: 3:7: cannot set freq 48000 to ep 0x82
[ 10.528547] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 10.529580] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 10.529823] usb 1-2.7: 3:8: cannot set freq 96000 to ep 0x82
[ 10.535379] usb 1-2.7: 3:2: cannot get min/max values for control 2 (id 3)
[ 10.535728] usbcore: registered new interface driver snd-usb-audio
[ 10.704372] usb 1-2.7: USB disconnect, device number 5
[ 11.396371] tegradc 15210000.nvdisplay: unblank
[ 11.453765] CPU1: shutdown
[ 11.456554] psci: CPU1 killed.
[ 11.479996] CPU2: shutdown
[ 11.482726] psci: CPU2 killed.
[ 11.670414] usb 1-2.7: new high-speed USB device number 8 using xhci-tegra
[ 11.872894] usb 1-2.7: New USB device found, idVendor=0bda, idProduct=570a
[ 11.880375] usb 1-2.7: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 11.891244] usb 1-2.7: Product: DELL S2340T Webcam
[ 11.898452] usb 1-2.7: Manufacturer: 56.18006.48131P04Y
[ 11.903718] usb 1-2.7: SerialNumber: 201209030001
[ 11.915356] uvcvideo: Found UVC 1.00 device DELL S2340T Webcam (0bda:570a)
[ 11.928759] input: DELL S2340T Webcam as /devices/3530000.xhci/usb1/1-2/1-2.7/1-2.7:1.0/input/input8
[ 12.154608] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 12.190660] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 12.966309] fuse init (API version 7.23)
[ 15.467287] IPVS: Creating netns size=1424 id=2
[ 15.914899] tegradc 15210000.nvdisplay: blank - powerdown
[ 15.984732] PD DISP2 index4 DOWN
[ 15.984824] PD DISP1 index3 DOWN
[ 15.984904] PD DISP0 index2 DOWN
[ 16.001010] tegradc 15210000.nvdisplay: unblank
[ 16.001024] PD DISP0 index2 UP
[ 16.001922] PD DISP1 index3 UP
[ 16.002001] PD DISP2 index4 UP
[ 16.003525] Parent Clock set for DC plld2
[ 16.004921] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 16.064631] tegradc 15210000.nvdisplay: unblank
[ 16.455581] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 16.712259] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 16.732460] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 16.847019] usb 1-2.7: USB disconnect, device number 8
[ 16.852193] usb 1-2.7: cannot submit urb (err = -19)
[ 16.857379] usb 1-2.7: 3:4: cannot set freq 48000 to ep 0x82
[ 16.992219] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.069275] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.136487] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.149390] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.276224] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.353248] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.420508] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.433698] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.560196] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.658786] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 17.714567] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 17.814364] usb 1-2.7: new high-speed USB device number 9 using xhci-tegra
[ 18.006533] usb 1-2.7: New USB device found, idVendor=0bda, idProduct=570a
[ 18.013631] usb 1-2.7: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 18.021451] usb 1-2.7: Product: DELL S2340T Webcam
[ 18.026542] usb 1-2.7: Manufacturer: 56.18006.48131P04Y
[ 18.032041] usb 1-2.7: SerialNumber: 201209030001
[ 18.047869] uvcvideo: Found UVC 1.00 device DELL S2340T Webcam (0bda:570a)
[ 18.063587] input: DELL S2340T Webcam as /devices/3530000.xhci/usb1/1-2/1-2.7/1-2.7:1.0/input/input9
[ 18.208017] IPVS: Creating netns size=1424 id=3
[ 18.294669] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 18.332072] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 18.714542] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 23.095123] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 27.739332] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 28.738949] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 37.763353] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 38.763300] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 47.786701] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 48.787318] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 53.235049] CFG80211-ERROR) wl_cfg80211_connect : Connectting with7c:95:f3:31:3f:83 channel (6) ssid “Islander_Student”, len (16)
[ 53.382135] CFG80211-ERROR) wl_notify_connect_status : connect failed event=0 e->status 1 e->reason 0
[ 53.405012] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 55.188254] CFG80211-ERROR) wl_cfg80211_connect : Connectting with7c:95:f3:31:3f:83 channel (6) ssid “Islander_Student”, len (16)
[ 55.321070] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 7c:95:f3:31:3f:83
[ 55.360843] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 55.370948] cfg80211: Regulatory domain changed to country: US
[ 55.376956] cfg80211: DFS Master region: FCC
[ 55.381302] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 55.391163] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 55.399269] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 55.408800] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 55.418507] CFG80211-ERROR) wl_notify_connect_status :
[ 55.418540] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm), (0 s)
[ 55.418542] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 55.418544] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 55.448118] wl_bss_connect_done succeeded with 7c:95:f3:31:3f:83
[ 57.811540] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 58.810839] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 67.835314] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 68.835235] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 77.017551] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 77.035335] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 77.042593] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 7c:95:f3:31:3f:83
[ 77.342346] CFG80211-ERROR) wl_cfg80211_disconnect : Link down event is not received
[ 77.365599] cfg80211: World regulatory domain updated:
[ 77.370755] cfg80211: DFS Master region: unset
[ 77.375186] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 77.384957] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.393060] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.401079] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.409136] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 77.418617] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 77.428148] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 77.436240] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.444296] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 77.457249] cfg80211: World regulatory domain updated:
[ 77.462397] cfg80211: DFS Master region: unset
[ 77.466763] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 77.476548] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.484559] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.492593] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.500602] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 77.510093] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 77.519573] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 77.527695] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 77.535717] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 77.858553] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 78.556241] IPVS: Creating netns size=1424 id=4
[ 78.858590] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 87.882561] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 88.882916] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 97.907403] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 98.906537] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 107.931281] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 108.930910] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 117.954833] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 118.955395] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 127.979426] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 128.979328] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 138.003316] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 139.003340] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 148.027276] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 149.026898] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 154.022542] usb 1-2.4: new high-speed USB device number 10 using xhci-tegra
[ 154.125327] usb 1-2.4: New USB device found, idVendor=0930, idProduct=6545
[ 154.132312] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 154.139941] usb 1-2.4: Product: DataTraveler 2.0
[ 154.144703] usb 1-2.4: Manufacturer: Kingston
[ 154.149200] usb 1-2.4: SerialNumber: 1C6F654E59A2EF11D928A79A
[ 154.157980] usb-storage 1-2.4:1.0: USB Mass Storage device detected
[ 154.165393] scsi host2: usb-storage 1-2.4:1.0
[ 155.195101] scsi 2:0:0:0: Direct-Access Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 4
[ 156.986874] sd 2:0:0:0: [sda] 30497664 512-byte logical blocks: (15.6 GB/14.5 GiB)
[ 156.994752] sd 2:0:0:0: [sda] Write Protect is off
[ 156.999562] sd 2:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 157.004832] sd 2:0:0:0: [sda] No Caching mode page found
[ 157.010195] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 158.050569] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 158.843885] sda: sda1
[ 158.848022] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 159.050540] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 159.250847] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 159.556969] IPVS: Creating netns size=1424 id=5
[ 168.074962] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 169.074769] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 178.099426] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 179.099308] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 188.123467] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 189.123445] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 198.147339] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 199.146720] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 208.171962] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 209.170965] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 218.194746] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 219.194768] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 228.218565] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 229.218641] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 238.242567] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 239.242540] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 248.266559] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 249.266546] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 258.290534] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 259.290531] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 268.314648] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 269.314612] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 278.338539] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 279.338512] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 288.362650] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 289.362587] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 296.884348] misc tegra_camera_ctrl: ISO BW req 2147483647 > 4687500 (max) capping to max
[ 296.892482] misc tegra_camera_ctrl: vi_v4l2_update_isobw: requested iso bw is larger than max
[ 298.386550] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 299.386573] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 308.410768] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 309.410566] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 318.434557] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 319.434553] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 328.458553] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 329.458528] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 329.752865] IPVS: Creating netns size=1424 id=6
[ 338.482539] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 339.482611] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 348.506560] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 349.506552] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 358.530542] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 359.530559] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 368.554547] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 369.554590] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 378.578547] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 379.578569] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 388.605995] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 389.602591] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 398.626560] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 399.628759] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 408.650776] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 409.650530] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 418.674556] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 419.674559] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 428.698575] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 429.698585] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 438.722551] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 439.722545] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 448.746565] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 449.746554] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 458.770553] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 459.770579] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 468.794582] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 469.794588] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 478.818770] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 479.818546] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 484.047865] usb 1-2.4: USB disconnect, device number 10
[ 488.842755] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 489.842730] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 498.866758] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 499.866722] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 508.890867] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 509.890738] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 518.914807] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 519.914691] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 528.938768] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 529.938747] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 538.962758] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 539.962688] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 548.986759] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 549.986738] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 559.014758] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 560.014684] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 569.034746] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 570.034675] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 579.058873] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 580.058810] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 589.082759] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 590.082647] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 599.106796] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 600.106707] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 609.130768] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 610.130727] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 619.154769] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 620.154700] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 629.178769] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 630.178666] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 639.202772] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 640.204236] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 645.826212] CFG80211-ERROR) wl_cfg80211_connect : Connectting with7c:95:f3:31:3f:83 channel (6) ssid “Islander_Student”, len (16)
[ 646.080829] CFG80211-ERROR) wl_notify_connect_status : connect failed event=0 e->status 1 e->reason 0
[ 646.110462] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 648.301328] CFG80211-ERROR) wl_cfg80211_connect : Connectting with7c:95:f3:31:3f:83 channel (6) ssid “Islander_Student”, len (16)
[ 648.374064] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 7c:95:f3:31:3f:83
[ 648.404167] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 648.415416] cfg80211: Regulatory domain changed to country: US
[ 648.421333] cfg80211: DFS Master region: FCC
[ 648.425827] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 648.435735] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 648.443828] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 648.453329] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 648.462850] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm), (0 s)
[ 648.470943] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 648.478983] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 648.569719] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 7c:95:f3:31:3f:83
[ 649.226765] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 650.226760] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 659.250774] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 660.250803] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 669.014630] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 669.031991] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 669.038996] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 7c:95:f3:31:3f:83
[ 669.274555] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 669.338347] CFG80211-ERROR) wl_cfg80211_disconnect : Link down event is not received
[ 669.362115] cfg80211: World regulatory domain updated:
[ 669.367269] cfg80211: DFS Master region: unset
[ 669.371755] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 669.381530] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 669.389628] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 669.397684] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 669.405753] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 669.415241] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 669.424728] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 669.432823] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 669.440829] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 669.453751] cfg80211: World regulatory domain updated:
[ 669.458899] cfg80211: DFS Master region: unset
[ 669.463276] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 669.473060] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 669.481077] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 669.489144] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 669.497156] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 669.506642] cfg80211: (52
University does not use a certificate.
Thank you for your inputs
[ 645.826212] CFG80211-ERROR) wl_cfg80211_connect : Connectting with7c:95:f3:31:3f:83 channel (6) ssid "Islander_Student", len (16)
[ 648.301328] CFG80211-ERROR) wl_cfg80211_connect : Connectting with7c:95:f3:31:3f:83 channel (6) ssid "Islander_Student", len (16)
Seems to contain some relevant information.
Did you try to connect with external usb wifi dongle?
Did you try contacting network guys in the university support team?
What is your University?
For example johnshopkins has specific instructions that involve to download wpa supplicant and add
config. Check if your University networking section contains some particular instructions or configuration files for Linux users or whatever.
http://www.it.johnshopkins.edu/services/network/wireless/linux.html
http://www.it.johnshopkins.edu/services/network/wireless/wpasupplicant.html
MIT has peculiar Kerberos involving method that is quite noticeable, in my opinion http://kb.mit.edu/confluence/display/istcontrib/Ubuntu+Linux+-+How+to+connect+to+MIT+SECURE+wireless
You may also refer to https://raspberrypi.stackexchange.com/questions/43359/connecting-to-universities-wpa2-enterprise-wifi-network
http://www.cs.upc.edu/lclsi/Manuales/wireless/files/wpa_supplicant.conf
I am at Texas A&M Corpus Christi, and will ask the IT group if there is something I should be doing specific, in addition to trying to connect with a USB dongle.
Thank you!
It seems that you are approaching (ISLANDER_STUDENT)
I have found an instruction for pc:
https://it.tamucc.edu/Network%20and%20Phone%20Connectivity%20/PDF/WirelessAccess.pdf
and an instruction for a mobile device
https://it.tamucc.edu/Network%20and%20Phone%20Connectivity%20/PDF/WirelessAccessMobile.pdf
they seem to be rather straightforward and don’t involve sophisticated manipulations.
You should be able to contact them with https://it.tamucc.edu/ContactUs.html
What if you try the approach as from the answer 2 at https://askubuntu.com/questions/279762/how-to-connect-to-wpa2-peap-mschapv2-enterprise-wifi-networks-that-dont-use-a-c:
cd /etc/NetworkManager/system-connections
sudo touch SSID #SSID is the name of the profile, e.g. eduroam
sudo nano Islander_Student
[ipv6]
method=auto
[connection]
id=Islander_Student #(e.g.EDUroam)
uuid=9e123fbc-0123-46e3-97b5-f3214e123456 #unique uuid will be created upon creation of this profile
type=802-11-wireless
[802-11-wireless-security]
key-mgmt=wpa-eap
auth-alg=open
[802-11-wireless]
ssid=Islander_Student
mode=infrastructure
mac-address=0A:12:3C:DA:C1:A5
security=802-11-wireless-security
[802-1x]
eap=peap;
identity=studentid123123
phase2-auth=mschapv2
password=mypass123123
[ipv4]
method=auto
what their support says is:
" Please select the following options. for EAP method select PEAP for phase 2 authentication Select MSCHAPV2 for CA Certificate select unspecified or do not check. Then log in with your normal islander id and password.
If you have any issues please give us a call at 361 825 2692."
I have tried all of the work around on that page, none of them worked.
In my opinion ,if you can check with usb wifi it will determine if the issue is with system-wide configuration, or with a particular wifi driver/ wifi device.
