I add a new camera sensor driver as the NVIDIA_Tegra_Linux_Driver_Package28.2 Start_L4T_Docs.html described. In the L4T_Docs, there are two method to add the sensor DTSI:
1.Using Plugin Manager
I add the new sensor DTSI as the e3326 sample, but do not have any sensor driver probe print info during system booting stage. Only when i change the status to okay definde in tegra186-quill-camera-modules.dtsi:
lrC1200_cam0: ov2775_a@36 {
status = “okay”;
the sensor driver can have the probe print info.
Normally, the status should be “disabled” in modules dtsi, and be “okay” status in tegra186-quill-camera-plugin-manager.dtsi.
Q1: Why my camera driver do not start to probe in Using Plugin Manager? Addtion, the new camera module do not have module_id or eeprom.
2.Using Main Platform Device Tree File
when i remove the following line: #include <t18x-common-plugin-manager/tegra186-quill-camera-plugin-manager.dtsi" in tegra186-quill-p3310-1000-a00-00-base.dtsi, burn the new dtb to the TX2 board, But,the kernel can not boot.
The Main Platform Device Tree method are suggest by the Start_L4T_Docs.html for my camera module which not have eeprom and BoardID.
Q2: How to remove the Plugin Manage and the kernel can boot okay? Have something need to notice?
Thinks!
