Issue with Basler acA1300-60gm camera being detected on PylonViewer on Jetson Nano
Post installation of the PylonViewer on both Windows and Unubtu OS, the GigE camera: Basler acA1300-60gm is being detected on Windows OS but not on the Jetson Nano.
I’ve installed Pylon Viewer 6.2.3 on Jetson Nano.
What drivers do I need to install to get the camera detected on Jetson Nano.?
Need help with detecting the camera on the Jetson Nano.
Please check with the vendor to confirm they support the device on Jetson Nano. One possibility is that the device is supports on other Jetson platforms instead of Jetson Nano. Would suggest confirm this with the vendor first.
The Basler support team got back with this response:
It appears that this camera was purchased 10 years ago, there are chances that the camera has malfunctioned.
Unfortunately we are not able to any further support.
The camera is working absolutely fine on Windows OS, but the camera is not being detected on PylonViewer on the Jetson Nano. So I don’t think it is an issue of the camera.
How do I check if the camera (Basler acA1300-60gm) is supported on the Jetson Nano? @DaneLLL
When you connect the camera to Jetson Nano developer kit, do you see any print in dmesg? Generally you will see prints indicating the camera is enumerated as highspeed or superspeed.
@DaneLLL I do not see any print messages.
Also, I could not find acA1300-60gm on this link. Does this mean it’s not supported on Jetson platforms?
If enumeration doesn’t happen, it is possible the camera is not supported. Generally enumeration should be triggered while connecting to either USB device.
