I have a Basler acA4112 GigE camera and I am trying to use it in the Jetson Nano. I installed the Pylon Camera Software Suite, which contains the IP Configurator, and is used to have the camera up & running. The problem is that the camera is not detected by the software/Jetson nano.
I would appreciate if someone has suggestions on how to setup GigE cameras in the Jetson nano.
Thank you
