Issue with downloading jetpack at SDK manager windows env
03:53:52 INFO: WSL Setup Preparation - target_image:  0| ‰iȲ.**
03:53:52 INFO: WSL Setup Preparation - target_image: --user, -u <ƐtDŽ>
03:53:52 INFO: WSL Setup Preparation - target_image:  Ɛ\ ‰iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: Linux Windows X ¤\ x:
03:53:52 INFO: WSL Setup Preparation - target_image: --export < |tDŽ>
03:53:52 INFO: WSL Setup Preparation - target_image: 0| tar |\ ŰȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: | tDŽ@ - \ %|  ǵȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --import <$XX> < |tDŽ> [5X]
03:53:52 INFO: WSL Setup Preparation - target_image:  tar |D 0\ 85Ȳ.
03:53:52 INFO: WSL Setup Preparation - target_image: 5X:
03:53:52 INFO: WSL Setup Preparation - target_image: --version <>
03:53:52 INFO: WSL Setup Preparation - target_image: 0 ` D iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --list, -l [5X]
03:53:52 INFO: WSL Setup Preparation - target_image: 0| iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --all
03:53:52 INFO: WSL Setup Preparation - target_image: ֬ $X  p x 0| hX
03:53:52 INFO: WSL Setup Preparation - target_image: --running
03:53:52 INFO: WSL Setup Preparation - target_image: ֬ ‰ x 0̹ iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --quiet, -q
03:53:52 INFO: WSL Setup Preparation - target_image: 0 tDŽ̹ \iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --verbose, -v
03:53:52 INFO: WSL Setup Preparation - target_image: 0 \ 8\ | \iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --set-default, -s
03:53:52 INFO: WSL Setup Preparation - target_image: 0| 0<\ $iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --set-default-version <>
03:53:52 INFO: WSL Setup Preparation - target_image: 0X 0 $X D iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --set-version <>
03:53:52 INFO: WSL Setup Preparation - target_image:  0X D iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --shutdown
03:53:52 INFO: WSL Setup Preparation - target_image: ‰ x 0  WSL 2 ɷ Ҭ 8D ̸iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --terminate, -t
03:53:52 INFO: WSL Setup Preparation - target_image:  0| ̸iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --unregister
03:53:52 INFO: WSL Setup Preparation - target_image: 0X ]D ͌iȲ.
03:53:52 INFO: WSL Setup Preparation - target_image: --help
03:53:52 INFO: WSL Setup Preparation - target_image: | \iȲ.
03:53:55 INFO: CuDNN on Target - target: Found file C:\Users\tmdrl\Downloads\nvidia\sdkm_downloads\cudnn-local-tegra-repo-ubuntu2204-9.3.0_1.0-1_arm64.deb with correct checksum, skip downloading.
03:53:56 INFO: WSL Setup Preparation - target_image: Task ‘PackageInstallTask4’ finished after 22.54 seconds
03:53:56 INFO: WSL Setup Preparation - target_image: Task completed successfully (Exit Code: 0)
03:53:56 DEBUG: WSL Setup Preparation - target_image: command finished successfully
03:53:56 INFO: WSL Setup Preparation - target_image: [ Component install Finished Successfully ]
03:53:56 INFO: WSL Setup Preparation - target_image: [ 225.22MB Used. Disk Avail on Partition C:\: 121.43GB ]
03:53:56 INFO: WSL Setup Preparation - target_image: [ NV_L4T_WSL_SETUP_WIDNOWS_IMAGE_COMP Install took 25s ]
03:53:56 SUMMARY: WSL Setup Preparation - target_image: Install completed successfully.
03:53:56 SUMMARY: TensorRT on Target - target: Depends on failed component
03:53:56 SUMMARY: TensorRT Runtime - target: Depends on failed component
03:53:56 SUMMARY: Multimedia API - target: Depends on failed component
03:53:56 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
03:53:56 SUMMARY: CUDA Runtime - target: Depends on failed component
03:53:56 SUMMARY: CuDNN on Target - target: Depends on failed component
03:53:56 SUMMARY: CuDNN Runtime - target: Depends on failed component
03:53:56 SUMMARY: OpenCV - target: Depends on failed component
03:53:56 SUMMARY: OpenCV Runtime - target: Depends on failed component
03:53:56 SUMMARY: CuPVA Runtime - target: Depends on failed component
03:53:56 SUMMARY: VPI on Target - target: Depends on failed component
03:53:56 SUMMARY: Jetson Platform Services - target: Depends on failed component
03:53:56 SUMMARY: VPI Runtime - target: Depends on failed component
03:53:56 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
03:53:56 SUMMARY: Nsight Systems - target: Depends on failed component
03:53:56 SUMMARY: Nsight Graphics - target: Depends on failed component
03:53:56 SUMMARY: Gstreamer - target: Depends on failed component
03:53:56 SUMMARY: DLA Compiler - target: Depends on failed component
03:53:56 SUMMARY: DateTime Target Setup - target: Depends on failed component
03:53:56 SUMMARY: WSL Flash Post Setup - flash: Depends on failed component
03:53:56 SUMMARY: Flash Jetson Linux - flash: Depends on failed component
03:53:56 SUMMARY: File System and OS - target_image: Depends on failed component
03:53:56 SUMMARY: Drivers for Jetson - target_image: Depends on failed component
03:53:56 SUMMARY: Windows USBIPD - target_image: Depends on failed component
03:53:56 SUMMARY: WSL Kernel Image - target_image: Depends on failed component
03:53:56 SUMMARY: WSL Ubuntu Instance - target_image: Depends on failed component
03:53:57 INFO: File System and OS - target_image: Found file C:\Users\tmdrl\Downloads\nvidia\sdkm_downloads\Tegra_Linux_Sample-Root-Filesystem_R36.5.0_aarch64.tbz2 with correct checksum, skip downloading.
03:54:00 INFO: CUDA Runtime - target: Found file C:\Users\tmdrl\Downloads\nvidia\sdkm_downloads\l4t-cuda-tegra-repo-ubuntu2204-12-6-local_12.6.11-1_arm64.deb with correct checksum, skip downloading.
03:54:00 DEBUG: running command < Start-ScheduledTask -TaskName “UnregisterPackageInstallTask” -TaskPath “\NVIDIA Corporation\SDK Manager\” >
03:54:00 DEBUG: command finished successfully
03:54:04 INFO: CUDA Toolkit for L4T - target: Found file C:\Users\tmdrl\Downloads\nvidia\sdkm_downloads\l4t-cuda-tegra-repo-ubuntu2204-12-6-local_12.6.11-1_arm64.deb with correct checksum, skip downloading.
INSTALLATION FAILEDPlease review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
![](C:\Program Files\NVIDIA Corporation\SDK Manager\resources\app\output\dist\electron\images\icon_retry.svg)
STOP TRYING
!(C:\Program Files\NVIDIA Corporation\SDK Manager\resources\app\output\dist\electron\images\NVIDIA-logo-dark.svg)
Copyright © 2026, NVIDIA CORPORATION. All rights reserved | NVIDIA Developer
I tried to fix every possible way, but still not working
Please press EXPORT LOG and upload for us to review.
Sorry for late,
After some more trouble shooting, the conclusion is on SSD.
After changing it, issue gone everything works well
