Hi to all.
I am having problems at the cmd $tar jxvf jedroid_v1.31.tar.bz2 -C ~/jedroid_workspace
The error is:
ubuntu@tegra-ubuntu:~/Downloads$ tar jxvf jedroid_v1.31.tar.bz2 -C ~/jedroid_workspace
bzip2: (stdin) is not a bzip2 file.
tar: Child returned status 2
tar: Error is not recoverable: exiting now
There you go…the problem is that whatever method you used to download the file downloaded the web page for downloads rather than the actual file. Some web pages are designed to make sure you click the “ok” button on some EULA before download begins (or else only works if logged in), so direct download with something like “wget” doesn’t work.
When I go there it requires a google login. After doing that, it says the URL doesn’t work. So the URL itself has an issue, plus you must log in to google to get there just to know.
