I’m attempting to initiate a live session from Revit (version 23.0.20.21), but I’m encountering a persistent issue. Each time I create a new live session, Revit crashes.
Below are the steps I’ve followed to create a live session:
- Open my RVT file (Note: This file is not hosted on Microsoft OneDrive).
- Export as Prop.
- Initiate a new live session.
At this point, the application consistently crashes.
Could you please assist me in identifying the root cause of this problem? Any guidance or suggestions would be greatly appreciated.
Thank you
Revit crash report :
dmpuserinfo.zip (1.7 MB)
Nucleus logs :
2024-05-02 14:00:27 [2,892ms] [Info] [carb.launcher.plugin] [33276] C:\b\w\29e5db4c08dcb0b0\source\plugins\carb.launcher\ProcessCommon.cpp:_readFromHandleThread():620: done the read thread for ‘launcher stderr reader’ for the process 12696.
2024-05-02 14:00:27 [2,892ms] [Info] [carb.launcher.plugin] [25308] C:\b\w\29e5db4c08dcb0b0\source\plugins\carb.launcher\ProcessCommon.cpp:_readFromHandleThread():620: done the read thread for ‘launcher stdout reader’ for the process 12696.
2024-05-02 14:00:27 [3,148ms] [Info] [omni.core] [444] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\omni.core\impl\servicesclients.cpp:connect():486: Connecting to Auth service…
2024-05-02 14:00:29 [4,225ms] [Info] [omni.server] [24284] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\omni.server\omniverseserver.cpp:OmniverseServer():121: waiting for Core to startup (done)
2024-05-02 14:00:29 [4,239ms] [Info] [omni.server] [24284] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\omni.server\omniverseserver.cpp:OmniverseServer():134: Omniverse C++ ApiServer server started.
2024-05-02 14:00:29 [4,971ms] [Error] [omni.core] [7500] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\common\childprocess.cpp:stderrReadCallback():31: From process omni-lft-service\omni-lft-service.exe:2024-05-02 16:00:29,748 - system_log - INFO - [WinError 1225] Le système distant a refusé la connexion réseau2024-05-02 14:00:29 [4,972ms] [Error] [omni.core] [7500] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\common\childprocess.cpp:stderrReadCallback():31: From process omni-lft-service\omni-lft-service.exe:2024-05-02 16:00:29,749 - system_log - ERROR - Traceback (most recent call last):
File “idl\connection\transport\omni.py”, line 166, in prepare
File “websockets\legacy\client.py”, line 650, in await_impl_timeout
File “asyncio\tasks.py”, line 445, in wait_for
File “websockets\legacy\client.py”, line 654, in await_impl
File “asyncio\base_events.py”, line 1081, in create_connection
File “asyncio\base_events.py”, line 1060, in create_connection
File “asyncio\base_events.py”, line 969, in _connect_sock
File “asyncio\proactor_events.py”, line 709, in sock_connect
File “asyncio\windows_events.py”, line 826, in _poll
File “asyncio\windows_events.py”, line 613, in finish_connect
ConnectionRefusedError: [WinError 1225] Le système distant a refusé la connexion réseauDuring handling of the above exception, another exception occurred:
File “lft\server.py”, line 556, in await_connection
File “idl\connection\transport\omni.py”, line 174, in prepare
idl.connection.transport.TransportError: [WinError 1225] Le système distant a refusé la connexion réseau2024-05-02 14:00:30 [5,973ms] [Error] [omni.core] [7500] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\common\childprocess.cpp:stderrReadCallback():31: From process omni-lft-service\omni-lft-service.exe:2024-05-02 16:00:30,750 - system_log - INFO - reconnecting …
2024-05-02 14:00:30 [5,977ms] [Error] [omni.core] [7500] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\common\childprocess.cpp:stderrReadCallback():31: From process omni-lft-service\omni-lft-service.exe:2024-05-02 16:00:30,753 - system_log - INFO - connected
2024-05-02 14:00:30 [5,981ms] [Error] [omni.core] [7500] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\common\childprocess.cpp:stderrReadCallback():31: From process omni-lft-service\omni-lft-service.exe:2024-05-02 16:00:30,758 - system_log - ERROR - Server started
2024-05-02 14:00:47 [22,251ms] [Fatal] [omni.core] [15336] c:\gitlab-runner\builds\sr9_1st2\0\omniverse\backend\api_server\source\plugins\omni.core\impl\deltamanager.cpp:pingTask():615: Failed to connect to DeltaApplier process.
