Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model:
- Driver Version:
Topic Description
Detailed Description
I am working on implementing semantic segmentation in Isaac Sim, but I’m encountering issues with applying semantic labels and colors as expected. I’d appreciate any help with this situation. Here’s a summary of my setup and the issues I’m facing:
- Objective:
- I aim to assign unique
semanticId
andsemanticColor
values to each object from a predefined YAML file and apply these attributes to objects in Isaac Sim. - When capturing segmentation images, I want each object to be visualized using the pre-defined
semanticColor
- Current Setup:
- I load
semanticId
andsemanticColor
mappings from a YAML file and assign them to each object. For each prim, I directly set attributes likesemanticData
andsemanticColor
usingprim.CreateAttribute
. - I’m using
rep.AnnotatorRegistry.get_annotator("semantic_segmentation")
to retrieve segmentation data, but the expected colors are not displayed correctly; only some objects are updated, or default colors are shown instead. - Even after setting
semanticData
andsemanticColor
, the segmentation capture does not seem to reflect these settings. To address this, I tried setting attributes in thesemantic:Semantics:<params>
format, but the issue persists.
- Current Issues:
- The
semanticColor
I assigned is not reflected in the actual segmentation image, and it seems like Isaac Sim might be assigning colors randomly. - Although I manually assigned
semanticData
andsemanticColor
attributes, I’m unable to accurately retrieve the color values throughrep.AnnotatorRegistry.get_annotator("semantic_segmentation")
. - The segmentation image does not accurately visualize objects with the predefined colors associated with their
semanticData
- Questions:
- How can I ensure that Isaac Sim correctly uses the user-defined color (
semanticColor
) for each semantic label (semanticData
) in segmentation? - Is there an alternative configuration needed besides the
format for these attributes? - Are there any recommended settings or steps I should check to ensure that the
semanticColor
values are applied correctly in the segmentation capture?
