Issues deploying pretrained policies in Isaac Sim
I am working with Isaac Sim / Lab and encountered some difficulties when deploying pretrained reinforcement learning policies.
Context:
  • My policies are trained in Isaac Lab using default PPO algorithm and SKRL framework (training script path is: IsaacLab\source\isaaclab_tasks\isaaclab_tasks\manager_based\locomotion\velocity\velocity_env_cfg.py
  • For deployment, I use a customized version of the example script: isaacsim\exts\isaacsim.robot.policy.examples\isaacsim\robot\policy\examples\robots\h1\H1FlatTerrainPolicy
Problems:
  • Weights format mismatch:
    • Isaac Lab saves weights .pt file as Python dictionary (dict with policy, value, and optimizer keys)
    • Isaac Sim’s policy loader expects a torch.jit._script.RecursiveScriptModule object to be loaded with torch.jit.load
    • Attempting torch.jit.load leads to errors like:
      RuntimeError: PytorchStreamReader failed locating file constants.pkl: file not found
  • Observation vector ambiguity**:**
    • The _compute_observation function must manually define the observation vector
    • However, in Isaac Lab manager-based training setup, the observation vector is abstracted away, making it unclear what the exact observation length / structure is.
Questions:
  • Is there an official or recommended workflow to convert SKRL-trained policies into TorchScript modules (torch.jit._script) compatible with Isaac Sim?
  • How can we extract the exact observation vector structure (dimension and components) from an Isaac Lab manager-based setup to ensure _compute_observation matches deployment requirements?
All in all, should we expect Isaac Lab’s pretrained policies (from SKRL or RSL-RL) to be deployable out-of-the-box in Isaac Sim, or is manual conversion always required?
Since, I am adapting the official example scripts rather than building from scratch, I assumed deployment would be seamless. Therefore, any guidance on the intended workflow would be greatly appreciated.
Isaac Sim Version
5.0.0
Operating System
Windows 10
GPU Information
  • Model: GeForce RTX 5070
  • Driver Version: 577.00
  • CUDA Version: 12.9
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
