When using the Jetson AGX Orin, a third-party sensor driver is installed, and according to its official reference, when using
After adding the user to the dialout group with the command
sudo usermod -G dialout -a $USER
newgrp dialout
I restarted Orin, and then I encountered a loop login problem that returned me to the user login screen, no matter how I entered the correct account password.
If I enter the command line interface, but press ctrl+alt+F2 to F12 the operation will enter a black screen interface (is completely black screen, without any cursor), and then press ctrl+alt+F1 will return to the login graphical interface. Therefore, it is impossible to enter the command line interface.
Rebooting does not solve this problem.
I also tried to use recovery mode, that is, press and hold the recovery button and then press the reset button and release recovery, Orin restarted, but and the problem was not solved.
Has anyone had this problem? What should I do?
