I’ve designed a custom PCB based on P3768-A04 with the following hardware -
USB0 to a USB connector for recovery
USB1 and USBSS0 to a USB3.1 connector
USB2 and USBSS2 to a USB3.1 connector
PCIe0_0, PCIe0_1, PCIe0_2 and PCIe0_3 to M.2.M (NVMe) connector
PCIE1_0 to additional PCIe GigE chipset
GigE to Ethernet connector
HDMI to connector.
I have removed the following from my design -
USB hub circuitry
USB-c circuitry
M.2 M (NVMe) freeing up PCIE2_0 and PCIE2_1
M.2 E socket (WiFi and BT) freeing up USB2 and PCIE1_0
Displayport
My concern is the use of USBSS2 and will this cause mapping options with my use of PCIe ports? With hindsight i think that i should have used USBSS1 instead of USBSS2?
Im afraid at this moment, i dont fully understand the UPHY mapping options which is what has caused my post.
Any guidance on whether (1) the above will work and (2) what changes i need to make to configuration would be most helpful.
