I had issues controlling the Jetbot keyboard input example. I followed the instructions on Jetbot Sample page was not able to move the Jetbot. I suspect that when I press the keys, the shortcut triggered instead of Jetbot Keyboard controller as when I press ‘w’ key, the move tool was highlighted and the Jetbot did not move. I was also already in Play mode.
Hi ped02,
I suspect your asses are old. please get the latest assets, and see if you still have the same issue.
Kindly,
Liila
Hi Liila,
I have checked the assets and they are new version. However I found that the problem might be due to me remote accessing the device and continuous key presses were not transmitted (I had someone press on the keyboard for me on the physical machine and it worked). Thanks and sorry for the trouble.
