I am trying to run the JetBot Lane Following reinforcement learning sample from here: https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/rl_samples.html
I believe everything should be set up properly, imported the fbx files into the Nucleus server, sourced setenv.sh, set up conda env etc. but I get the following errors when running python jetbot_train.py:
This error multiple times:
2020-12-23 11:53:20 [18,079ms] [Warning] [omni.usd] inputs:diffuse_color_constant already exists but type is mismatched. Removing old type (SdfAssetPath) and creating new one (GfVec3f)
2020-12-23 11:53:20 [18,079ms] [Error] [omni.client.plugin] Main: usd_plugin: Type mismatch for </World/Env/Tiles/Tile_22/Looks/White_material/White_material.inputs:diffuse_color_constant>: expected 'SdfAssetPath', got 'GfVec3f'
And finally this error, where I am a bit puzzled that it says ERROR_OUT_OF_DEVICE_MEMORY:
2020-12-23 11:53:23 [21,170ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2020-12-23 11:53:23 [21,170ms] [Error] [carb.graphics-vulkan.plugin] vkAllocateMemory failed.
2020-12-23 11:53:23 [21,170ms] [Error] [rtx.resourcemanager.plugin] Texture creation failed for the device: 0.
Fatal Python error: Segmentation fault
Current thread 0x00007f80b812c340 (most recent call first):
File "/home/robotlab/Downloads/isaac-sim-2020.2.2007-linux-x86_64-release/_build/linux-x86_64/release/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/scripts/omnikit.py", line 195 in update
File "/home/robotlab/Downloads/isaac-sim-2020.2.2007-linux-x86_64-release/python_samples/jetbot/jetbot_env.py", line 112 in step
File "/home/robotlab/Downloads/isaac-sim-2020.2.2007-linux-x86_64-release/python_samples/jetbot/jetbot_env.py", line 158 in reset
File "/home/robotlab/anaconda3/envs/isaac-sim/lib/python3.6/site-packages/stable_baselines3/common/vec_env/dummy_vec_env.py", line 59 in reset
File "/home/robotlab/anaconda3/envs/isaac-sim/lib/python3.6/site-packages/stable_baselines3/common/vec_env/vec_transpose.py", line 60 in reset
File "/home/robotlab/anaconda3/envs/isaac-sim/lib/python3.6/site-packages/stable_baselines3/common/base_class.py", line 477 in _setup_learn
File "/home/robotlab/anaconda3/envs/isaac-sim/lib/python3.6/site-packages/stable_baselines3/common/on_policy_algorithm.py", line 208 in learn
File "/home/robotlab/anaconda3/envs/isaac-sim/lib/python3.6/site-packages/stable_baselines3/ppo/ppo.py", line 264 in learn
File "jetbot_train.py", line 49 in train
File "jetbot_train.py", line 83 in <module>
Isaac Sim opens briefly, loads the assets and the errors occur. Any advice or ideas how to get it running?
System:
Isaac Sim 2020.2.2007
Ubuntu 18.04
Quadro RTX3000, driver version 455.38
i7-10875H CPU @ 2.30GHz × 16
32 GB RAM
