JetPack 3.2.1 — Maintenance Release for Jetson TX1/TX2/TX2i
We’re pleased to announce that JetPack 3.2.1 is now available for Jetson TX2/TX2i and Jetson TX1.
JetPack component changes:
  • (TX2/TX2i only) L4T 28.2.1 "point release" including Cboot related update
JetPack installer changes:
  • GDPR compliance
  • Switch all downloads to HTTPS
L4T 28.2.1 is a Jetson TX2/TX2i only release. See L4T Release Notes for the list of fixed issues.
L4T 28.2 remains the current version for Jetson TX1 and is available in JetPack 3.2.1.
JetPack 3.2.1 installer available here - https://developer.nvidia.com/embedded/jetpack
will it support the below?
./flash.sh jetson-tx2 nvme
it turned out that it would neither support the above nor the below that causes loop-reboot
sudo ./flash.sh jetson-tx2 mmcblk1p1
perhaps I missed some partitions though, because it finished flashing in less then minute in the case above versus the case below that takes minutes and works:
sudo ./flash.sh jetson-tx2 mmcblk0p12
Though perhaps the issue doesn’t belong to the thread topic.
Hi Andrey, it seems you have found the correct command, for others on the thread, please see the Quick Start Guide if you are flashing using the L4T tools directly:
$ sudo ./flash.sh jetson-tx2 mmcblk0p1
