JetPack 4.2.2 is not listed in sdkmanager
Hi everyone
I have a product based on JetPack 4.2.2 but I’m not able to find this SDK listed on sdkmanager --archived versions anymore. I need this version because my base OS has custom drivers and I use Jetson SDK Components compatible with 4.2.2.
Searching on forum I’ve found this post reporting a similar problem and the solution was to add this SDK version to sdkmanager again.
Can you please help?
Hi lbarrospth8e,
Please download JetPack-4.2.2 ‘L4T Driver Package’ and ‘Sample Root Filesystem’ from here:
It’s old version, so if you want to use SDK Manager, suggest you can use the latest JetPack version.
Hi carolyuu,
First of all, thank you by your quick response. I will do what you suggested and it will resolve my OS generation problem, but I also need Jetson SDK Components versions compatible with 4.2.2: CUDA Toolkit , CUDA-X AI, cuDNN, TensorRT and etc. Where can I find this packages?
Sorry for the late response, is this still an issue to support? Thanks
Consider starting with:
sdkmanager --archivedversions
I don’t know which release is the earliest available by that, but see if what you want is there.
