Jetson Xavier NX 16 Gb Jetpack 5.0.2 L4t 35.1.0
I configrate Jetson, Jetson-clocks is running. CPU frequency is 1.9GHz, Gpu freq is 1.1Ghz.
When I used imx 477 with gstreamer or nvgstcapture 1.0, there is a break in the incoming images, imx219 works fine. But there is no problem while using the jetpack 4.6 Jetson Nano. Can you help plzz?
