I have successfully installed IMX477 DRIVE on Jetson Xavier NX.
When I tried to start camera
gst-launch-1.0 nvarguscamerasrc ! nvdrmvideosink
This is the error.
L4T version: 35.1.0
Jetpack: 5.0.2
How can I solve this problem?
This is the error.
L4T version: 35.1.0
Jetpack: 5.0.2
It is hard to say what is the specific issue given the information that you have provided. There could be many causes, even hardware problems.
My recommendation is to start testing with v4l2 directly:
v4l2-ctl --set-fmt-video=width=3840,height=2160,pixelformat=RG10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=IMX477.raw
Also, could you please provide the output of the V4L2 trace log.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
sudo cat /sys/kernel/debug/tracing/trace
Also the output of the dmesg log when running the v4l2-ctl command can be helpful to figure out the issue.
Jafet Chaves,
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
