Trying to flash Orin at 24.04 host, but it continues to fail when creating OS image. (File System and OS part)
Exported logs file is attached
SDKM_logs_JetPack_6.2.1_(rev._1)_Linux_for_Jetson_AGX_Orin_64GB_2025-10-08_10-50-22.zip (643.7 KB)
Based on the provided context, it appears that you are trying to flash the Jetson AGX Orin using the l4t_initrd_flash.sh script, but the process is failing when creating the OS image file system and OS partition.
To troubleshoot this issue, I would recommend checking the following:
SDKMlogsJetPack621rev1LinuxforJetsonAGXOrin64GB20251008105022zip) may contain error messages or clues about the failure. Check the logs for any errors related to the OS image creation or partitioning process.l4t_initrd_flash.sh script. Ensure that the correct options are used for the target device and the desired flash configuration.flash.sh instead of l4t_initrd_flash.sh).Comparing the provided context to the available information, I notice that the l4t_initrd_flash.sh script is used for flashing the Jetson AGX Orin, but the flash.sh script is also mentioned in the context. The flash.sh script is used for flashing the entire device, including the miniUEFI. It’s possible that using the flash.sh script with the correct options might resolve the issue.
To further assist, I would need more information about the specific error messages or logs related to the failure. Additionally, providing more details about the host machine’s configuration and the target device’s configuration might help identify the root cause of the issue.
Some questions to confirm:
Native machine with 24.04.
My orin is a dev kit 64GB
I was able to flash at another machine with 22.04.
I guess it’s the issue with ubuntu 24.04
Please try another 22.04 machine and use sdk manager to flash again.
