Hi, I’m using devkit Orin NX(16G) board to flash our custom kernel.
I followed Kernel Customization — NVIDIA Jetson Linux Developer Guide
to rebuild kernel、dtb and modules, update the initrd img. But when I started flash to my board, it get these err message.
csp@csp:/HDD/xinhao/IIPB/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit-super internal
Please install the Secureboot package to use initrd flash for fused board
# Entry added by NVIDIA initrd flash tool
/HDD/xinhao/IIPB/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
rpcbind: another rpcbind is already running. Aborting
Export list for localhost:
15:19:28.457 - Debug: Checking UFW status and NFS port rules...
15:19:28.494 - Debug: UFW is not active. NFS port is accessible.
15:19:28.495 - Debug: Checking VPN connections...
15:19:28.497 - Debug: IPSec service is not running.
15:19:28.498 - Debug: VPN routes none in tun|tap|ppp|vpn|gpd.
15:19:28.499 - Debug: No VPN connection detected.
/HDD/xinhao/IIPB/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p -c bootloader/generic/cfg/flash_t234_qspi.xml --showlogs --network usb0 jetson-orin-nano-devkit-super internal
* Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
/HDD/xinhao/IIPB/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh: line 516: [: : integer expression expected
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY="" /HDD/xinhao/IIPB/Linux_for_Tegra/flash.sh --no-flash --sign -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit-super internal
# L4T BSP Information:
# R36 , REVISION: 4.4
# User release: 0.0
ECID is 0x80012344705DF6C86C00000008FF8040
copying device_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
copying emc_fuse_dev_params(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying minratchet_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
Existing emcfuse(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
./tegraflash.py --chip "0x23" --applet "/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0090 ] Reading fuses
[ 0.0102 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0103 ] Assuming zero filled SBK key
[ 0.0100 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0153 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0226 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[ 0.0272 ] Parsing partition layout
[ 0.0274 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0282 ] Kernel DTB used: None
[ 0.0282 ] WARNING: dce base dtb is not provided
[ 0.0282 ] Parsing partition layout
[ 0.0285 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0289 ] Creating list of images to be signed
[ 0.0292 ] Generating ratchet blob
[ 0.0293 ] Generating coldboot mb1-bct
[ 0.0296 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.0298 ] MB1-BCT version: 0.13
[ 0.0311 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0314 ] Added Platform Config 9 data with size :- 100
[ 0.0314 ]
[ 0.0314 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.0314 ]
[ 0.0314 ] Updating mb1-bct with firmware information
[ 0.0317 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0329 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0332 ] Generating SHA2 Hash for mb1bct
[ 0.0342 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.0348 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.0347 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0349 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0359 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0360 ] Assuming zero filled SBK key
[ 0.0369 ] Warning: pub_key.key is not found
[ 0.0368 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0375 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.0378 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0386 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0388 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0424 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0434 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0468 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0470 ] adding BCH for mb2_t234_aligned.bin
[ 0.0490 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0546 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0547 ] adding BCH for mb2_t234_aligned.bin
[ 0.0617 ] Filling MB1 storage info
[ 0.0617 ] Parsing dev params for multi chains
[ 0.0665 ] Generating br-bct
[ 0.0668 ] Updating dev and MSS params in BR BCT
[ 0.0668 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0672 ] Updating bl info
[ 0.0674 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0675 ] WARNING: boot chain is not completed. set to 0
[ 0.0684 ] Generating signatures
[ 0.0688 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0689 ] Assuming zero filled SBK key
[ 0.0744 ] Warning: pub_key.key is not found
[ 0.0741 ] Parsing dev params for multi chains
[ 0.0741 ] Generating br-bct
[ 0.0743 ] Updating dev and MSS params in BR BCT
[ 0.0743 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0747 ] Updating bl info
[ 0.0748 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0749 ] WARNING: boot chain is not completed. set to 0
[ 0.0760 ] Generating SHA2 Hash
[ 0.0770 ] Sha saved in br_bct_BR.sha
[ 0.0766 ] Get Signed section of bct
[ 0.0769 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0773 ] Signing BCT
[ 0.0777 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0778 ] Assuming zero filled SBK key
[ 0.0791 ] Sha saved in br_bct_BR.sha
[ 0.0793 ] Warning: pub_key.key is not found
[ 0.0789 ] Updating BCT with signature
[ 0.0792 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0794 ] Offset :4608 Len :3584
[ 0.0799 ] Generating SHA2 Hash
[ 0.0803 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0804 ] Assuming zero filled SBK key
[ 0.0818 ] Sha saved in br_bct_BR.sha
[ 0.0816 ] Updating BCT with SHA2 Hash
[ 0.0818 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.0820 ] Offset :4608 Len :3584
[ 0.0823 ] Offset :68 Len :8124
[ 0.0825 ] Generating coldboot mb1-bct
[ 0.0827 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.0830 ] MB1-BCT version: 0.13
[ 0.0843 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0844 ] Added Platform Config 9 data with size :- 100
[ 0.0845 ]
[ 0.0845 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.0845 ]
[ 0.0845 ] Updating mb1-bct with firmware information
[ 0.0847 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0857 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0860 ] Generating SHA2 Hash for mb1bct
[ 0.0870 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.0877 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.0875 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0876 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0887 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0887 ] Assuming zero filled SBK key
[ 0.0894 ] Warning: pub_key.key is not found
[ 0.0893 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0898 ] Generating recovery mb1-bct
[ 0.0899 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.0901 ] MB1-BCT version: 0.13
[ 0.0919 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0920 ] Added Platform Config 9 data with size :- 100
[ 0.0921 ]
[ 0.0921 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.0921 ]
[ 0.0921 ] Updating mb1-bct with firmware information
[ 0.0923 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0932 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.0934 ] Generating SHA2 Hash for mb1bct
[ 0.0942 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 0.0946 ] Sha saved in mb1_bct_MB1.sha
[ 0.0944 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.0946 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.0955 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0956 ] Assuming zero filled SBK key
[ 0.0965 ] Warning: pub_key.key is not found
[ 0.0964 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0970 ] Info: Skip generating mem_bct because sdram_config is not defined
[ 0.0970 ] Copying signatures
[ 0.0974 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1023 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1024 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1024 ] Boot Rom communication
[ 0.1027 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1029 ] BR_CID: 0x80012344705DF6C86C00000008FF8040
[ 0.1037 ] Sending bct_br
[ 0.1037 ] Sending mb1
[ 0.1042 ] Sending psc_bl1
[ 0.1170 ] Sending bct_mb1
[ 0.1239 ] Boot Rom communication completed
[ 0.1243 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.1246 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.1248 ] adding BCH for applet_t234_aligned.bin
[ 0.1319 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1320 ] Assuming zero filled SBK key
[ 0.1334 ] Warning: pub_key.key is not found
[ 0.1333 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.1344 ] Sending mb2_applet...
[ 0.1346 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.1349 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 0.3492 ] Sending applet
[ 0.4547 ] completed
[ 0.4552 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.4555 ] MB2 Applet version 01.00.0000
[ 0.6426 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.6428 ] MB2 Applet version 01.00.0000
[ 0.6454 ] Parsing fuse info as per xml file
[ 0.6457 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[ 0.6459 ] MagicId=0x45535546 version=0x2
[ 0.6461 ] trying to read fuse with MB2 Applet
[ 0.6466 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[ 0.6470 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.6471 ] MB2 Applet version 01.00.0000
[ 0.6496 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.6561 ] Fuse read successful
[ 0.6572 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[ 0.6576 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.6577 ] MB2 Applet version 01.00.0000
[ 0.6601 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.6659 ] Fuse read successful
[ 0.6671 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[ 0.6678 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.6680 ] MB2 Applet version 01.00.0000
[ 0.6705 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.6764 ] Fuse read successful
[ 0.6775 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[ 0.6779 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.6780 ] MB2 Applet version 01.00.0000
[ 0.6804 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.6864 ] Fuse read successful
[ 0.6875 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[ 0.6881 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.6885 ] MB2 Applet version 01.00.0000
[ 0.6908 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.6968 ] Fuse read successful
[ 0.6980 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[ 0.6986 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.6988 ] MB2 Applet version 01.00.0000
[ 0.7013 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7072 ] Fuse read successful
[ 0.7083 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[ 0.7089 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7091 ] MB2 Applet version 01.00.0000
[ 0.7115 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7175 ] Fuse read successful
[ 0.7186 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[ 0.7192 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7194 ] MB2 Applet version 01.00.0000
[ 0.7218 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7277 ] Fuse read successful
[ 0.7289 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[ 0.7296 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7298 ] MB2 Applet version 01.00.0000
[ 0.7322 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7381 ] Fuse read successful
[ 0.7393 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[ 0.7398 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7400 ] MB2 Applet version 01.00.0000
[ 0.7425 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7484 ] Fuse read successful
[ 0.7496 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[ 0.7501 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7505 ] MB2 Applet version 01.00.0000
[ 0.7529 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7588 ] Fuse read successful
[ 0.7600 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[ 0.7605 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7606 ] MB2 Applet version 01.00.0000
[ 0.7631 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7692 ] Fuse read successful
[ 0.7703 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[ 0.7709 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7711 ] MB2 Applet version 01.00.0000
[ 0.7737 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7796 ] Fuse read successful
[ 0.7807 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[ 0.7811 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7813 ] MB2 Applet version 01.00.0000
[ 0.7837 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7896 ] Fuse read successful
[ 0.7907 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[ 0.7913 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7915 ] MB2 Applet version 01.00.0000
[ 0.7940 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.7999 ] Fuse read successful
[ 0.8010 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[ 0.8016 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8017 ] MB2 Applet version 01.00.0000
[ 0.8043 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8103 ] Fuse read successful
[ 0.8114 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[ 0.8119 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8121 ] MB2 Applet version 01.00.0000
[ 0.8147 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8205 ] Fuse read successful
[ 0.8216 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[ 0.8220 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8221 ] MB2 Applet version 01.00.0000
[ 0.8247 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8307 ] Fuse read successful
[ 0.8317 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[ 0.8321 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8322 ] MB2 Applet version 01.00.0000
[ 0.8346 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8406 ] Fuse read successful
[ 0.8418 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[ 0.8424 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8426 ] MB2 Applet version 01.00.0000
[ 0.8449 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8508 ] Fuse read successful
[ 0.8520 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[ 0.8525 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8527 ] MB2 Applet version 01.00.0000
[ 0.8552 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8611 ] Fuse read successful
[ 0.8622 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[ 0.8628 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8630 ] MB2 Applet version 01.00.0000
[ 0.8654 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8713 ] Fuse read successful
[ 0.8754 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8755 ] MB2 Applet version 01.00.0000
[ 0.8782 ] Retrieving board information
[ 0.8784 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.8786 ] MB2 Applet version 01.00.0000
[ 0.8811 ] Saved platform info in chip_info.bin
[ 0.8867 ] Chip minor revision: 1
[ 0.8867 ] Bootrom revision: 0x7
[ 0.8868 ] Ram code: 0x1
[ 0.8868 ] Chip sku: 0xd3
[ 0.8869 ] Chip Sample: prod
[ 0.8877 ] Retrieving EEPROM data
[ 0.8877 ] tegrarcm_v2 --oem platformdetails eeprom cvm /HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.8880 ] MB2 Applet version 01.00.0000
[ 0.8904 ] Saved platform info in /HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/cvm.bin
[ 0.9277 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9279 ] MB2 Applet version 01.00.0000
[ 0.9303 ] Dumping customer Info
[ 0.9306 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.9308 ] MB2 Applet version 01.00.0000
[ 0.9332 ] Saved bct in tmp.bct
[ 0.9540 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 0.9542 ] C[ 0.9546 ] ustomer data saved in /HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 0.9546 ] Rebooting to recovery mode
[ 0.9548 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 0.9576 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9578 ] MB2 Applet version 01.00.0000
[ 0.9601 ] Booting to recovery mode
[ 0.9604 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 0.9606 ] MB2 Applet version 01.00.0000
Board ID(3767) version(301) sku(0000) revision(G.1)
Preset RAMCODE is 1
Chip SKU(00:00:00:D3) ramcode(1) fuselevel(fuselevel_production) board_FAB(301)
emc_opt_disable_fuse:(0)
Copy /HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-nv-super.dtb to /HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-nv-super.dtb.rec
Generated UUID 2e84909f-a1e0-43ff-af3b-5d5e42039a6b for mounting root APP partition.
copying bctfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0000-sdram-l4t.dts)... done.
copying pinmux_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/ramdisk_tmp /HDD/xinhao/IIPB/Linux_for_Tegra/bootloader /HDD/xinhao/IIPB/Linux_for_Tegra
72850 blocks
gzip: /HDD/xinhao/IIPB/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.148-tegra
cp: cannot stat '/HDD/xinhao/IIPB/Linux_for_Tegra/rootfs/usr/lib/modules/5.15.148-tegra/modules.builtin.alias.bin': No such file or directory
warning: cp -f /HDD/xinhao/IIPB/Linux_for_Tegra/rootfs/usr/lib/modules/5.15.148-tegra/modules.builtin.alias.bin /HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/modules/5.15.148-tegra/modules.builtin.alias.bin
96478 blocks
Making Recovery image...
copying recdtbfile(/HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-nv-super.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000134191 s, 149 kB/s
Existing sosfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/bpmp_t234-TE980M-A1_prod.bin) reused.
copying bpfdtbfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0000-3768-super.dtb)... done.
Existing camerafw(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-nv-super.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Existing rcm_tbcfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/uefi_jetson_minimal.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.401303 s, 167 MB/s
Sync'ing esp.img ... done.
copying tbcdtbfile(/HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-nv-super.dtb)... done.
copying cfgfile(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi.xml) to flash.xml... done.
Existing flashapp(/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/HDD/xinhao/IIPB/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)... done.
/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_minimal_with_dtb.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo, --bldtb tegra234-p3768-0000+p3767-0000-nv-super.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --cpubl_rcm uefi_jetson_minimal.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE980M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0000-3768-super.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3767-0000-sdram-l4t.dts --cust_info custinfo_out.bin --bct_backup --boot_chain A --ramcode 1
version 1.0.0
[ 0.0103 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0100 ] Parsing partition layout
[ 0.0103 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0126 ] Change tegra234-bpmp-3767-0000-3768-super.dtb to tegra234-bpmp-3767-0000-3768-super_with_odm.dtb
[ 0.0430 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0000-3768-super_with_odm.dtb tegra234-bpmp-3767-0000-3768-super_with_odm_tmp.dtb
[ 0.1758 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo to tegra234-p3768-0000+p3767-0000-nv-super_with_odm_overlay.dtb.updated
[ 0.1759 ] Concatenating bl dtb to cpubl binary
[ 0.1769 ] Concatenating bl dtb:(tegra234-p3768-0000+p3767-0000-nv-super_with_odm_overlay.dtb.updated), to cpubl binary: uefi_jetson_minimal.bin
[ 0.1778 ] MB2 binary: mb2_t234.bin
[ 0.1778 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[ 0.1855 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[ 0.3822 ] Generating coldboot mb2-bct
[ 0.3822 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 0.3824 ] WARNING: unknown property 'tfc_version'
[ 0.3838 ] WARNING: unknown property 'addr_header_version'
[ 0.3935 ] Updating mb2-bct with storage information
[ 0.3939 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.3952 ] Concatenating mb2-bct to mb2 binary
[ 0.3952 ] mb2_bin_file = mb2_t234.bin
[ 0.3952 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.3967 ] DCE binary: display-t234-dce.bin
[ 0.3967 ] Kernel DTB used: tegra234-p3768-0000+p3767-0000-nv-super_with_odm_overlay.dtb.updated
[ 0.3967 ] Concatenating kernel-dtb to dce-fw binary
[ 0.3967 ] dce_bin = display-t234-dce.bin
[ 0.3967 ] kernel_dtb = tegra234-p3768-0000+p3767-0000-nv-super_with_odm_overlay.dtb.updated
[ 0.3967 ] dce_with_dtb = display-t234-dce_with_tegra234-p3768-0000+p3767-0000-nv-super_with_odm_overlay.dtb.bin
[ 0.3998 ] Update display-t234-dce_with_tegra234-p3768-0000+p3767-0000-nv-super_with_odm_overlay.dtb.bin to dce_fw partitions
[ 0.4007 ] Parsing partition layout
[ 0.4010 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.4017 ] Creating list of images to be signed
[ 0.4019 ] Generating ratchet blob
[ 0.4019 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[ 0.4066 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.4110 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[ 0.4159 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[ 0.4212 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.4274 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
Error: Return value 1
Command cpp -nostdinc -x assembler-with-cpp -D IN_DTS_CONTEXT -I .. -I ../generic/BCT tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dts
cp: cannot stat 'signed/*': No such file or directory
cp: cannot stat 'signed/flash.xml.tmp': No such file or directory
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --bldtb tegra234-p3768-0000+p3767-0000-nv-super.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "secureflash;reboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-3768-super_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt" --bct_backup
saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
$ cd bootloader
$ sudo bash ./flashcmd.txt
Error: /HDD/xinhao/IIPB/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /HDD/xinhao/IIPB/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
And flash failure due to the missing file modules.builtin.alias.bin , compared with the original rootfs after apply_binary.sh. The module output I build dont have this file and the original rootfs has it.
cp: cannot stat ‘signed/*’: No such file or directory
cp: cannot stat ‘signed/flash.xml.tmp’: No such file or directory
Do you know why this err happend?
