Jetpack 7.2 on AGX orin boot up failed
Hi Nvidia team,
I downloaded the Jetpack 7.2 and followed the link build it successfully.
I used the command, sudo ./flash.sh jetson-agx-orin-devkit internal, to flash the image on AGX Orin.
Here is my flash log. It showed me *** The target generic has been flashed successfully. ***
flashlog.txt (132.4 KB)
However, I can’t have my AGX Orin boot up properly.
Here is my debug message.
putty _202606111725.log (67.8 KB)
I tested all the steps on AGX Orin with devkit. My AGX Orin is 32GB. Do you know what the problem is?
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Based on the provided context, I found a similar issue in the Community Solutions section.
In Topic #237860, the user faced a similar issue where the Jetson AGX Orin 32GB did not respond after flashing. The accepted solution suggested trying a different command to flash the board:
$ sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
You can try this command to see if it resolves the issue. If the problem persists, it may be helpful to capture the UART console log for further debugging.
Additionally, in Topic #353658, the user experienced a boot failure after restoring a clone image on the AGX Orin Industrial module. The accepted solution recommended referring to the README_backup_restore.txt and using the ./tools/backup_restore/l4t_backup_restore.sh script instead.
However, since your issue is specifically related to booting up after flashing Jetpack 7.2 on the AGX Orin 32GB, I couldn’t find a direct solution in the provided context. You may want to try the suggested command from Topic #237860 and see if it resolves the issue.
If the problem persists, I recommend checking the Jetson AGX Orin documentation and forums for more information on troubleshooting boot issues with Jetpack 7.2.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Hi Nvidia team,
It’s my fault. Jetpack 7.2 is fine. I had a building environment of Jetpack 6.2 before. And I upgraded to the Jetpack7.2 and didn’t integrate it properly.
Now the AGX Orin with devkit can boot up properly.
