我们自研的T5000主板实际使用场景可能会经常非法断电,想咨询下官方是否有做过相关测试或者是否有说明文档,另外想咨询下如果系统损坏,是否只能重新烧录系统,处理烧录系统外,是否还有其他解决办法?
Not sure what does this mean, it’s also difference with your title description - “JETPACK7.1的系统能否支持多次非法断电”
T5000上使用的是JETPACK7.1,我们产品实际使用场景会多次开关机(>1000),需要保证多次开关机后,主板能正常进入系统无异常
You will need to run the reboot test on your device to meet your requirement.
Once any failure, please provide the log, then we can help to investigate to provide the suggestion.
