Hi
I’m currently integrating Orin with a 10G Broadcom PHY, but I’m facing issues specifically with the 5G speed mode. Iperf3 is giving me low speed measurements when receiving data, coupled with a high retransmit count.
iperf3 -c 10.167.61.19 -p 10001 -t 30
Connecting to host 10.167.61.19, port 10001
[ 5] local 10.167.61.45 port 36286 connected to 10.167.61.19 port 10001
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 143 MBytes 1.20 Gbits/sec 71 218 KBytes
[ 5] 1.00-2.00 sec 139 MBytes 1.16 Gbits/sec 67 95.8 KBytes
[ 5] 2.00-3.00 sec 140 MBytes 1.18 Gbits/sec 66 122 KBytes
[ 5] 3.00-4.00 sec 134 MBytes 1.13 Gbits/sec 55 209 KBytes
[ 5] 4.00-5.00 sec 84.0 MBytes 705 Mbits/sec 83 17.4 KBytes
[ 5] 5.00-6.00 sec 975 KBytes 7.99 Mbits/sec 28 17.4 KBytes
[ 5] 6.00-7.00 sec 975 KBytes 7.99 Mbits/sec 28 17.4 KBytes
[ 5] 7.00-8.00 sec 975 KBytes 7.99 Mbits/sec 28 17.4 KBytes
[ 5] 8.00-9.00 sec 88.5 MBytes 743 Mbits/sec 51 331 KBytes
[ 5] 9.00-10.00 sec 144 MBytes 1.21 Gbits/sec 75 296 KBytes
[ 5] 10.00-11.00 sec 131 MBytes 1.10 Gbits/sec 62 122 KBytes
[ 5] 11.00-12.00 sec 111 MBytes 929 Mbits/sec 74 17.4 KBytes
[ 5] 12.00-13.00 sec 1.19 MBytes 9.98 Mbits/sec 72 17.4 KBytes
[ 5] 13.00-14.00 sec 1.19 MBytes 9.99 Mbits/sec 28 17.4 KBytes
[ 5] 14.00-15.00 sec 121 MBytes 1.01 Gbits/sec 56 148 KBytes
[ 5] 15.00-16.00 sec 149 MBytes 1.25 Gbits/sec 71 148 KBytes
[ 5] 16.00-17.00 sec 38.3 MBytes 321 Mbits/sec 103 17.4 KBytes
[ 5] 17.00-18.00 sec 1.19 MBytes 9.99 Mbits/sec 28 17.4 KBytes
[ 5] 18.00-19.00 sec 59.3 MBytes 497 Mbits/sec 41 131 KBytes
[ 5] 19.00-20.00 sec 149 MBytes 1.25 Gbits/sec 70 131 KBytes
[ 5] 20.00-21.00 sec 141 MBytes 1.19 Gbits/sec 64 183 KBytes
[ 5] 21.00-22.00 sec 139 MBytes 1.16 Gbits/sec 66 174 KBytes
[ 5] 22.00-23.00 sec 135 MBytes 1.14 Gbits/sec 70 174 KBytes
[ 5] 23.00-24.00 sec 144 MBytes 1.20 Gbits/sec 61 165 KBytes
[ 5] 24.00-25.00 sec 136 MBytes 1.14 Gbits/sec 76 26.1 KBytes
[ 5] 25.00-26.00 sec 0.00 Bytes 0.00 bits/sec 63 17.4 KBytes
[ 5] 26.00-27.00 sec 1.19 MBytes 9.98 Mbits/sec 28 17.4 KBytes
[ 5] 27.00-28.00 sec 22.1 MBytes 186 Mbits/sec 31 200 KBytes
[ 5] 28.00-29.00 sec 145 MBytes 1.22 Gbits/sec 64 165 KBytes
[ 5] 29.00-30.00 sec 155 MBytes 1.30 Gbits/sec 68 165 KBytes
[ 5] 0.00-30.00 sec 2.59 GBytes 743 Mbits/sec 1748 sender
[ 5] 0.00-30.00 sec 2.59 GBytes 742 Mbits/sec receiver
I also see the following kernel errors coming up sometimes while running iperf:
[ 251.550361] nvethernet 6810000.ethernet: [xpcs_lane_bring_up][477][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 251.550853] nvethernet 6810000.ethernet eth1: Link is Up - 5Gbps/Full - flow control rx/tx
[ 299.228680] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1001, return: -19
[ 299.228687] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1003, return: -19
I’m only seeing the issue for the 5G mode. 10G and 2.5G are working without any problems. Both PHY and MAC are configured in XFI mode. There are no issues when sending data, only when receiving.
I’m running the tests by connecting our custom carrier board (with Broadcom PHY) to an Orin dev kit.
This is our current device tree configuration
ethernet@6810000 {
status = "okay";
nvidia,mac-addr-idx = <1>;
/* 0:XFI 10G, 1:XFI 5G, 2:USXGMII 10G, 3:USXGMII 5G */
nvidia,phy-iface-mode = <0>;
/* 0:5G, 1:10G */
nvidia,uphy-gbe-mode = <1>;
nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(Y, 1) 0>;
phy-handle = <&bcm_phy>;
phy-mode = "10gbase-r";
mdio {
/delete-node/ ethernet_phy@0;
bcm_phy: ethernet_phy@1 {
compatible = "ethernet-phy-ieee802.3-c45";
reg = <0x1>;
nvidia,phy-rst-pdelay-msec = <1000>;
nvidia,phy-rst-duration-usec = <1000>;
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA234_MAIN_GPIO(Y, 3) IRQ_TYPE_LEVEL_LOW>;
