Jetson AGX Orion thermal design
Hi, Jetson AGX orin Thermal design guide defines balanced and unbalanced workload. Can someone help me understand at what cases the unit will be under “unbalanced workload”. Is it during some particular operation or is it valid during transient run.
The Jetson AGX Orin Thermal Design Guide defines two types of workloads: balanced and unbalanced. A balanced workload refers to a situation where the system is running a mix of tasks that utilize the CPU, GPU, and memory in a balanced manner, resulting in a relatively even distribution of heat across the system.
On the other hand, an unbalanced workload occurs when the system is running a task that heavily utilizes one component, such as the GPU, while the other components are relatively idle. This can cause a significant increase in temperature in the heavily utilized component, leading to an unbalanced thermal profile.
In the case of the Jetson AGX Orin, an unbalanced workload can occur during various operations, such as:
  1. GPU-intensive tasks: When running tasks that heavily utilize the GPU, such as graphics rendering, video encoding, or deep learning inference, the GPU can become the dominant heat source, leading to an unbalanced thermal profile.
  2. CPU-intensive tasks: Similarly, when running tasks that heavily utilize the CPU, such as scientific simulations or data compression, the CPU can become the dominant heat source, leading to an unbalanced thermal profile.
  3. Memory-intensive tasks: Tasks that heavily utilize memory, such as data processing or machine learning training, can also lead to an unbalanced thermal profile, as the memory components can become the dominant heat source.
  4. Transient operations: During transient operations, such as boot-up, shutdown, or sudden changes in workload, the system can experience an unbalanced thermal profile due to the rapid changes in power consumption and heat generation.
In comparison, the Jetson Xavier NX and Jetson AGX Xavier series also experience unbalanced workloads, but the specific scenarios may differ due to differences in their architectures and thermal designs.
To mitigate the effects of unbalanced workloads, the Jetson AGX Orin Thermal Design Guide recommends various techniques, such as:
  1. Thermal throttling: Reducing the clock speed or voltage of the dominant heat source to prevent overheating.
  2. Heat spreading: Using thermal interfaces or heat sinks to spread the heat more evenly across the system.
  3. Airflow management: Ensuring adequate airflow around the system to help dissipate heat.
  4. System design: Designing the system to minimize thermal hotspots and ensure even heat distribution.
By understanding the scenarios that can lead to unbalanced workloads and implementing these mitigation techniques, developers can design and optimize their systems to maintain a balanced thermal profile and ensure reliable operation.
Balanced and unbalanced workload is to indicate how the system loading is distributed between say CPU, GPU, SOC, CV power domain IPs. Whether the compute is too CPU centric or GPU centric or memory/IO centric for example. The hot spot location on the SOC will be different depending on the use case like whether it is in CPU domain or GPU domain.
