It is a new AGX and I was able to play it but after a week I am not able to boot it.
Issue:
at first, I see just the NVIDIA logo after a few seconds, The screen becomes black and after a few seconds again I see the NVIDIA logo, it is always repeated doing this.
Hi @lyang1
could you providee output of executing of df -h at the host pc? M inimum 50gb should be available for successfull flashing;
Also could you reflash the boards from command line adding your user email address to the line provided below?
Also customizing the install and download paths so that it wil match some folders at your host PC?
obviously there is no enough space to conduct the operation?
at least 50gb should be required
when using the sdcard with 95 gb, make sure to point two path to the sdcard folders, in the command below:
Are you flash image on SDCard or emmc or NVMe?
If you are using SDK Manager to flash image, it will flash on your emmc.
Please share the uart log for check. Thanks!
could you extend what were the outcomes with the sdcard attempt, please?
you may also try to uninstall the sdkmanager package, installatinos, all downloaded content & try again
do you have by any chance some other Host PC to try with?
