When AGX Xavier is power-on, there is a certain probability that it cannot enter the desktop. By viewing the debug serial port log, it will stop at the same point when it fails to start normally.
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069b000
[ 0.000000] Found lut_mem: 00002008@a0695000
[ 1.953721] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
WARNING: pll_d3 has no dyn ramp
Attached is the debugging information for normal startup and abnormal startup. Please help analyze the possible causes of abnormal startup. Thanks.
failed.txt (26.2 KB)
pass.txt (28.3 KB)
