I’m using Jetson AGX Xavier Developer Kit (OS:Ubuntu18.04) and I seem to have deleted libc6 by mistake.
I don’t know if this is the cause or not, but the boot screen shows kernel panic, reboot in 5 seconds, and I can no longer log in.
I also tried flushing the OS with Jetpack 4.1.1 installer, but it doesn’t proceed from the following screen.
Enter
# L4T BSP Information:
# R31 (release), REVISION: 1.0, GCID: 13194883, BOARD: t186ref, EABI: aarch64,
# DATE: Wed Oct 31 22:26:16 UTC 2018
Is there a way to flush the OS and find out why it is not proceeding?
I have tried flashing it using JetPack 4.4.1 with the SDK manager, but the
In STEP03 SETUP PROCESS, it seems to become INSTALLATION FAILED.
I attached the log generated by EXPORT LOGS.
Sorry for the huge amount of log, but is there anything you can find out from the log? SDKM_logs_JetPack_4.4.1_Linux_for_Jetson_AGX_Xavier_2020-11-13_10-42-28.zip (540.4 KB)
I checked and found arm64 in the system arch list, so I followed the instructions you gave me.
But I still got an error with apt-get update.
It said Certificate verification failed, so I installed ca-certificates and the installation of jetpack proceeded successfully.
