Can PCIe interface(GEN4) of Jetson_AGX_Xavier connect reverse?
Thanks,
John Yang
Thanks,
John Yang
It mean the PCIe P/N lane reversal.(Gen3 & Gen4)
Thanks,
John yang
May I ask is there any reason you cannot follow the OEM design guide?
Because our PCIe Riser board is too small,
so need P/N lane reversal to improve layout routing.
Thanks,
John yang
Yes…lane polarity inversion works on Jetson-Xavier board’s Rx lanes… Please check whether the same is supported by the endpoint that you are going to connect to the slot.
Understand
Thank you!
