It seems that when we use nvarguscamerasrc or argus to capture the core of the CPU up to 100%, i have noticed that the jetson reset when this latter up to 100% as you can see in the attached picture.
Do you have any idea what it has this behavior ? Notice that am using the MAXN power mode.
I think there is an issue with JetPack (Maybe only in 4.3), because i’ve tested the camera capture with Yocto customized OS, i didn’t had any reset, and the fan is launched automatically, so the jetson doesn’t heat up.
