I am working with the Xavier dev kit and have Jetson 4.3 release installed. I have 2 FLIR camera installed on the Xavier unit.
I have an issue where the Xavier shutdowns right away. It was easy to create the issue.
Here are my test scenarios:
- When I run my software and with the jetson_clocks at the highest settings and nvpmodel = 0, the Xavier shutdown.
- When I run my software with the jetson_clocks is INACTIVE and nvpmodel = 2, the Xavier does NOT shutdown
For #1, I was able to run the “jtop” to capture the current activity BEFORE it shutdown. See below the screen shot. Is there a reason why the Xavier would shutdown at the maximum power? What should I do to debug this? Any logs I can look at?
I have 3 other Xavier that are in the same #1 setup and have no problem with them.
Any thoughts?
thanks ahead of time
