Hi Team,
I am Using Jetson AGX Xavier SOM Module in my design i have few queries to be clarified. please provide info on the following item.
1.In my design i have 3 interfaces for external display . HDMI connector, Type C over DP and eDP connector . Could you confirm if i can connect 3 Displays at a time and will all 3 interfaces work at the same time ??
- Does Jetson has inbuilt PMIC for RTC?? Is there any other connection required apart from connecting external Li battery to VCC_RTC ???
Could you share the contact or part number for the Jetson SOM Module Heatsink, Fan, Heatsink Channel Plate, TTP??
Jetson Firmware update via J512 Type C connector is over USB 2.0 lines??
Booting Time of Jetson SOM ??
