After a reboot my machine went into efi shell mode, I’ve found the boot image under /boot and tried to make it manually but it just fails.
I’ve even tried pointing directly to the boot image /boot/image
And /boot/initrd but none of them worked.
It does not have a GRUB I could check and update the boot file.
Please use the uart serial console to operate the board and share log. It would be hard to understand you issue by just a photo of your monitor.
Also, please provide more information about your issue. For example, why only you hit this issue while others won’t. You must have added something. We would like to know what did you change.
