Jetson Dev. Kit Vs Jetson Module
Dear all,
Just a question to remove my doubt:
The Jetson Dev. Kit has just one MIPI connector, which not allow multiples cameras support (Not USB).
The Jetson Module can accept 4 cameras MIPI 2 lanes.
In this case, If I want to use 4 cameras, I will need to develop my own dev board for the Jeston Module.
That’s right ?
Thank you for your help.
Best regards,
Chris.
Yes, on devkit only CSI0 and CSI2 are routed out to connectors. CSI1, CSI3 and CSI4 are only connected to TPs. Also you can refer to design guide in DLC for 4 cameras connection.
Hello Trumany,
Thanks for your informations.
So actually with the Nano dev board, it’s impossible.
Do I really need to buy the Jetson Module or using the one I have (Dev kit) and build my own dev board ?
Regards,
The module is same, no need to buy another one if you already had. Your own carrier board is necessary to implement 4 CSI cameras design.
Thanks Trumany,
This is what I was thinking.
Do you know when Nvidia will launch the Dev Board design schematic for the Nano ?
Thanks for all.
Regards,
No ETA yet, please keep following updates in DLC.
Ok thank you.
