Jetson Nano B01 Dev Kit Green Power LED Blinking
Hi, I am testing the current draw of my jetson nano with a bench power supply. The bench power is set on 5V but can only output a max of 3.20A. The problem is that the power LED keeps on flickering. Why is this happening? I only have my SD card installed on jetson with no external devices attached. When I supply with a standard 5.2V 2.4A charger through micro-USB this does not happen.
Hi, this looks like your power supply issue. You can probe the voltage level of point on board to check if it is stable 5V when power on.
