Can you install jetpack 4.2 on Jetson Nano B01? I’m using my Jetson Nano for the Jetbot but having a lot of issues using B01. I’m not sure if it’s just the version problem.
B01 requires a different carrier board revision versus A02. You can use JetPack for these, and it is even recommended. However, if you are sharing a carrier board among the different revisions, then this will cause failure.
