The company I work for is working on setting up studies with the nano and a camera. We purchased one nano for testing. The Jetson Nano Developer Kit. We got everything up and running as expected, and purchased 10 more to begin provisioning and rolling out. These 10 Nanos are different than the first. After Trumany sharing the proper models, We received the ‘Bo1’ and the first model was the ‘A01’. The issue with the Bo1 is that it will not power on, the LED light is on the motherboard, but it will not boot into the OS. I have tried the SD card and cables from the successful A01 setup, still no go.
Is there anyone who has used this R5 ( with 2 camera connectors rather than the power pins. ) and has been able to get it to power on successfully. If so, what have you done to get it to power on. The motherboard led light is on, but will not power the device to boot up.
Also, is there a way to ensure we receive the correct model when making this purchase? I do not want to do a return just to receive the same exact device.
