Hi @WayneWWW,
sorry, this is actually not the first boot log. In this log you see a SD flashed, with the first login and with some of my libraries installed. So, it is near the exact copy of the crashed sd, but without the boot issue.
I’ll provide you also a log of the first boot.
I think you should use a fresh sdcard image. If this boot failure is due to hardware, then swapping the image should always reproduce error.
yes, each time that I flashed a new sd or I flashed a crashed SD with a new standard img of jetson nano, all worked fine.
But after a couple of month appears the same boot issue, and I can’t understand why… I’ll check the boot log also on a new sd at the first boot, we will see if there is something different…
Thank you for your support @WayneWWW
If you could get this error again, please also remember the to save the uart log.
