Jetson Nano Boot Loop
Hi there, I have just received an Nvidia Jetson Nano and attempted to install the Nvidia Jetson Nano OS (nv-jetson-nano-sd-card-image-r32.2.3.zip) on a 32 GB class 10 Micro SD flashed to the SD card using balenaEtcher. I have then inserted the SD card and powered it up using a micro USB cable connected to a 5V 4A USB power adaptor. However, upon booting it shows the Nvidia logo for a few seconds then prints out the log shown in the image attached below and reboots in a loop after that.
Can you recommend what I should do to rectify this and get it booting up properly or what the causes may be?
Cheers,
Thomas
https://photos.app.goo.gl/Lb9NSq3m7X82ATy76
Please also try to use sdkmanager to flash your board.
