I still cannot get a clear reason for the problem. Here is what I tried.
I attempted UART connection, strictly following the provided article. I change the minicom configuration to point to the correct USB but when I run “sudo minicom” with the Jetson connected, I get the following in the dmesg terminal:
pl2303 ttyUSB0: pl2303_get_line_request - failed: -32
Nothing appears in the minicom terminal and when I exit minicom, I see this in the dmesg terminal:
pl2303 ttyUSB0: error sending break = -32
After unsuccessfully trying to solve the errors, I decided to try again remote connection using JupyterLab on http://192.168.55.1:8888. Fortunately, it does not freeze anymore and I can access the Jetson console and execute dmesg from there.
The camera still does not work and to investigate further I did some more testing using another camera and a Raspberry Pi. I tried both cameras on the Jetson and they did not start. Then I tried both cameras on the Raspberry Pi and they both worked. Definitely the problem is not in the camera.
Following I will add the errors that I see using dmesg in the Jetson JupyterLab terminal, both with the camera attached and without it.
Jetson Nano with attached camera:
[ 3.262785] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 3.262855] tegradc tegradc.1: No lt-data, using default setting
[ 3.262880] tegradc tegradc.1: No hpd-gpio in DT
[ 3.262909] tegradc tegradc.1: DT parsed successfully
[ 3.262958] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 3.264367] tegradc tegradc.1: dpd enable lookup fail:-19
[ 3.268618] tegradc tegradc.1: probed
[ 3.279714] edid invalid
[ 3.306768] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 3.362862] tegradc tegradc.1: fb registered
[ 4.563169] tegra-vii2c 546c0000.i2c: --- register dump for debugging ----
[ 4.570068] tegra-vii2c 546c0000.i2c: I2C_CNFG - 0x22c00
[ 4.575395] tegra-vii2c 546c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 4.582278] tegra-vii2c 546c0000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 4.588032] tegra-vii2c 546c0000.i2c: I2C_FIFO_STATUS - 0x800070
[ 4.594047] tegra-vii2c 546c0000.i2c: I2C_INT_MASK - 0xac
[ 4.599453] tegra-vii2c 546c0000.i2c: I2C_INT_STATUS - 0x0
[ 4.604945] tegra-vii2c 546c0000.i2c: msg->len - 2
[ 4.609743] tegra-vii2c 546c0000.i2c: is_msg_write - 1
[ 4.614889] tegra-vii2c 546c0000.i2c: buf_remaining - 0
[ 4.620124] tegra-vii2c 546c0000.i2c: i2c transfer timed out, addr 0x0010, data 0x00
[ 4.627938] imx219 6-0010: imx219_board_setup: error during i2c read probe (-110)
[ 4.635453] imx219 6-0010: board setup failed
[ 4.639927] imx219: probe of 6-0010 failed with error -110
[ 6.099212] tegra-vii2c 546c0000.i2c: --- register dump for debugging ----
[ 6.106096] tegra-vii2c 546c0000.i2c: I2C_CNFG - 0x22c00
[ 6.111420] tegra-vii2c 546c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 6.118293] tegra-vii2c 546c0000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 6.124036] tegra-vii2c 546c0000.i2c: I2C_FIFO_STATUS - 0x800070
[ 6.130039] tegra-vii2c 546c0000.i2c: I2C_INT_MASK - 0xac
[ 6.135434] tegra-vii2c 546c0000.i2c: I2C_INT_STATUS - 0x0
[ 6.140916] tegra-vii2c 546c0000.i2c: msg->len - 3
[ 6.145704] tegra-vii2c 546c0000.i2c: is_msg_write - 1
[ 6.150839] tegra-vii2c 546c0000.i2c: buf_remaining - 0
[ 6.156062] tegra-vii2c 546c0000.i2c: i2c transfer timed out, addr 0x0040, data 0x00
[ 6.163853] ina3221x 6-0040: ina3221 reset failure status: 0xffffff92
[ 6.170493] ina3221x: probe of 6-0040 failed with error -110
[ 7.094104] cgroup: cgroup2: unknown option "nsdelegate"
[ 13.427237] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 13.427241] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 13.427244] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 13.427247] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 13.427250] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 13.427252] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 13.427255] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 13.427258] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 13.427262] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 13.443352] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 14.985868] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 16.494201] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 17.999645] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 19.519445] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 21.030603] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 22.545547] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 23.667227] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 23.667230] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 23.667234] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 23.667236] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 23.667239] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 23.667241] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 23.667244] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 23.667247] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 23.667251] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 24.056272] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 25.562089] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 33.907781] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 33.907810] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 33.907838] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 33.907862] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 33.907888] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 33.907912] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 33.907937] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 33.907962] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 33.907994] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
Jetson Nano without attached camera:
[ 3.424819] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.448136] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.448201] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.448230] imx219 6-0010: board setup failed
[ 3.448327] imx219: probe of 6-0010 failed with error -121
[ 4.434152] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.440547] tegradc tegradc.1: No lt-data, using default setting
[ 4.442131] edid invalid
[ 4.449088] tegradc tegradc.1: No hpd-gpio in DT
[ 4.453722] tegradc tegradc.1: DT parsed successfully
[ 4.458796] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 4.466953] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.468361] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 4.485882] tegradc tegradc.1: probed
[ 4.503940] tegradc tegradc.1: fb registered
[ 5.142510] cgroup: cgroup2: unknown option "nsdelegate"
[ 11.370965] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 12.922666] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 14.429778] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 14.706170] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 14.706174] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 14.706177] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 14.706180] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 14.706182] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 14.706185] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 14.706188] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 14.706190] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 14.706195] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 15.936410] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 17.464335] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 18.968264] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 20.476082] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 21.992985] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 23.442442] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
[ 24.946762] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 24.946794] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 24.946825] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 24.946852] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 24.946881] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 24.946909] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 24.946938] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 24.946966] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 24.947000] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 35.186109] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 35.186113] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 35.186116] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 35.186119] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 35.186122] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 35.186125] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 35.186128] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 35.186131] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 35.186135] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
If it can be helpful, I can provide the whole dmesg logs.
Is it possible to identify the problem from the logs above?
In case it is a hardware problem, I don’t know what details to provide when bringing the Jetson to the shop where I bought it, as it is still in warranty.
