Jetson Nano Developer Kit (4gb) doesn't boot after System Update (only shows Nvidia Logo)
Hello Jerry, sorry for the late reply, here are the bootloader messages from the serial console.
I hope this is the correct information you need.
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-dd84d362)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x830e6
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.233] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI …
[0000.280] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.301] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI …
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.532] Bootloader DTB Load Address: 0x83000000
[0000.536] BoardID = 3448, SKU = 0x0
[0000.539] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.543] Nano-SD: checking PT table on QSPI …
[0000.548] Loading NvTbootKernelDTB
[0000.614] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.693] Kernel DTB Load Address: 0x83100000
[0000.698] BoardID = 3448, SKU = 0x0
[0000.701] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.705] Nano-SD: checking PT table on QSPI …
[0000.711] Loading cboot binary
[0000.827] Verifying EBT in OdmNonSecureSBK mode
[0000.868] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.875] Bootloader downloaded successfully.
[0000.880] BoardID = 3448, SKU = 0x0
[0000.883] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.887] Nano-SD: checking PT table on QSPI …
[0000.891] PT: Partition NCT NOT found !
[0000.895] Warning: Find Partition via PT Failed
[0000.899] Next binary entry address: 0x92c00258
[0000.904] BoardId: 3448
[0000.908] Overriding pmu board id with proc board id
[0000.913] Display board id is not available
[0000.917] BoardID = 3448, SKU = 0x0
[0000.921] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.924] Nano-SD: checking PT table on QSPI …
[0001.029] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.089] /bpmp deleted
[0001.091] SC7EntryFw header found loaded at 0xff700000
[0001.286] OVR2 PMIC
[0001.288] Bpmp FW successfully loaded
[0001.292] BoardID = 3448, SKU = 0x0
[0001.295] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.299] Nano-SD: checking PT table on QSPI …
[0001.304] WB0 init successfully at 0xff780000
[0001.308] Set NvDecSticky Bits
[0001.312] GSC2 address ff53fffc value c0edbbcc
[0001.318] GSC MC Settings done
[0001.321] BoardID = 3448, SKU = 0x0
[0001.324] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.328] Nano-SD: checking PT table on QSPI …
[0001.333] TOS Image length 53680
[0001.336] Monitor size 53680
[0001.339] OS size 0
[0001.355] Secure Os AES-CMAC Verification Success!
[0001.359] TOS image cipher info: plaintext
[0001.363] Loading and Validation of Secure OS Successful
[0001.379] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.383] NvTbootPackSdramParams: start.
[0001.389] NvTbootPackSdramParams: done.
[0001.392] Tegraboot started after 51833 us
[0001.396] Basic modules init took 899913 us
[0001.400] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.406] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.411] Next stage binary read took 102860 us
[0001.416] Carveout took -126354 us
[0001.419] CPU initialization took 497943 us
[0001.423] Total time taken by TegraBoot 1374362 us
[0001.428] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 11:29:29, Jun 14 2021
ERROR: Error initializing runtime service trusty_fast
[0001.550] RamCode = 0
[0001.552] get_emc_table_offset: Can’t find emc-table node
[0001.557] LPDDR4 Training: Can’t find emc-table node
[0001.603]
[0001.604] Debug Init done
[0001.607] Marked DTB cacheable
[0001.610] Bootloader DTB loaded at 0x83000000
[0001.614] Marked DTB cacheable
[0001.617] Kernel DTB loaded at 0x83100000
[0001.621] DeviceTree Init done
[0001.634] Pinmux applied successfully
[0001.638] gicd_base: 0x50041000
[0001.642] gicc_base: 0x50042000
[0001.645] Interrupts Init done
[0001.649] Using base:0x60005090 & irq:208 for tick-timer
[0001.654] Using base:0x60005098 for delay-timer
[0001.659] platform_init_timer: DONE
[0001.662] Timer(tick) Init done
[0001.666] osc freq = 38400 khz
[0001.670]
[0001.671] Welcome to L4T Cboot
[0001.674]
[0001.675] Cboot Version: 00.00.2018.01-t210-39562017
[0001.680] calling constructors
[0001.683] initializing heap
[0001.686] initializing threads
[0001.689] initializing timers
[0001.691] creating bootstrap completion thread
[0001.696] top of bootstrap2()
[0001.699] CPU: ARM Cortex A57
[0001.702] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.706] initializing platform
[0001.714] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.718] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.723] Macronix QSPI chip present
[0001.726] SPI device register
[0001.729] init boot device
[0001.732] allocating memory for boot device(SPI)
[0001.736] registering boot device
[0001.745] QSPI bdev is already initialized
[0001.749] Enable APE clock
[0001.751] Un-powergate APE partition
[0001.755] of_register: registering tegra_udc to of_hal
[0001.760] of_register: registering inv20628-driver to of_hal
[0001.766] of_register: registering ads1015-driver to of_hal
[0001.771] of_register: registering lp8557-bl-driver to of_hal
[0001.777] of_register: registering bq2419x_charger to of_hal
[0001.783] of_register: registering bq27441_fuel_gauge to of_hal
[0001.794] gpio framework initialized
[0001.798] of_register: registering tca9539_gpio to of_hal
[0001.803] of_register: registering tca9539_gpio to of_hal
[0001.808] of_register: registering i2c_bus_driver to of_hal
[0001.814] of_register: registering i2c_bus_driver to of_hal
[0001.819] of_register: registering i2c_bus_driver to of_hal
[0001.825] pmic framework initialized
[0001.828] of_register: registering max77620_pmic to of_hal
[0001.834] regulator framework initialized
[0001.838] of_register: registering tps65132_bl_driver to of_hal
[0001.844] initializing target
[0001.850] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.858] board ID = D78, board SKU = 0
[0001.861] Skipping Z3!
[0001.866] fixed regulator driver initialized
[0001.885] initializing OF layer
[0001.888] NCK carveout not present
[0001.891] Skipping dts_overrides
[0001.896] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.913] I2C Bus Init done
[0001.915] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.926] I2C Bus Init done
[0001.928] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.939] I2C Bus Init done
[0001.941] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.952] I2C Bus Init done
[0001.954] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.965] I2C Bus Init done
[0001.967] of_children_init: Ops found for compatible string maxim,max77620
[0001.978] max77620_init using irq 118
[0001.983] register ‘maxim,max77620’ pmic
[0001.987] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.993] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.004] I2C Bus Init done
[0002.007] NCK carveout not present
[0002.017] Find /i2c@7000c000’s alias i2c0
[0002.021] get eeprom at 1-a0, size 256, type 0
[0002.030] Find /i2c@7000c500’s alias i2c2
[0002.034] get eeprom at 3-a0, size 256, type 0
[0002.038] get eeprom at 3-ae, size 256, type 0
[0002.042] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.048] I2C slave not started
[0002.051] I2C write failed
[0002.053] Writing offset failed
[0002.056] eeprom_init: EEPROM read failed
[0002.060] pm_ids_update: eeprom init failed
[0002.065] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.095] pm_ids_update: The pm board id is 3448-0000-400
[0002.102] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.110] pm_ids_update: pm id update successful
[0002.115] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.145] pm_ids_update: The pm board id is 3449-0000-400
[0002.151] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.159] pm_ids_update: pm id update successful
[0002.189] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.195] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.203] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.209] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.217] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0002.224] Plugin Manager: Parse ODM data 0x000a4000
[0002.237] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.252] Find /i2c@7000c000’s alias i2c0
[0002.256] get eeprom at 1-a0, size 256, type 0
[0002.265] Find /i2c@7000c500’s alias i2c2
[0002.268] get eeprom at 3-a0, size 256, type 0
[0002.273] get eeprom at 3-ae, size 256, type 0
[0002.277] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.283] I2C slave not started
[0002.286] I2C write failed
[0002.288] Writing offset failed
[0002.291] eeprom_init: EEPROM read failed
[0002.295] pm_ids_update: eeprom init failed
[0002.299] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.329] pm_ids_update: The pm board id is 3448-0000-400
[0002.336] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.343] pm_ids_update: pm id update successful
[0002.347] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.377] pm_ids_update: The pm board id is 3449-0000-400
[0002.383] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.390] pm_ids_update: pm id update successful
[0002.421] Add serial number:1422919145299 as DT property
[0002.429] Applying platform configs
[0002.435] platform-init is not present. Skipping
[0002.440] calling apps_init()
[0002.446] Couldn’t find GPT header
[0002.450] Proceeding to Cold Boot
[0002.453] starting app android_boot_app
[0002.457] Device state: unlocked
[0002.460] display console init
[0002.469] could not find regulator
[0002.472] hdmi cable connected
[0002.487] edid read success
[0002.505] DT entry for leds-pwm not found
[0002.509] edid read success
[0002.511] width = 640, height = 480, frequency = 25174825
[0002.517] width = 640, height = 480, frequency = 25174825
[0002.522] width = 640, height = 480, frequency = 25174825
[0002.528] width = 640, height = 480, frequency = 25174825
[0002.533] width = 1920, height = 1080, frequency = 148500000
[0002.539] width = 1280, height = 720, frequency = 74250000
[0002.544] width = 1920, height = 540, frequency = 74250000
[0002.550] width = 1920, height = 1080, frequency = 148351648
[0002.555] width = 1280, height = 720, frequency = 74175824
[0002.561] width = 1920, height = 1080, frequency = 148351648
[0002.566] width = 1280, height = 720, frequency = 74175824
[0002.572] width = 720, height = 576, frequency = 26973026
[0002.577] width = 720, height = 480, frequency = 26973026
[0002.583] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.590] tmds-config node not found
[0002.594] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.609] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.617] could not find regulator
[0002.620] could not find regulator
[0002.623] could not find regulator
[0002.652] using default cmu settings
[0002.655] dc_hdmi_enable, starting HDMI initialisation
[0002.661] dc_hdmi_enable, HDMI initialisation complete
[0002.666] list and configure display window
[0002.675] display console init completed
[0002.686] subnode volume_up is not found !
[0002.690] subnode back is not found !
[0002.694] subnode volume_down is not found !
[0002.698] subnode menu is not found !
[0002.702] Gpio keyboard init success
[0002.782] found decompressor handler: lz4-legacy
[0002.797] decompressing blob (type 1)…
[0002.867] load_bmp_blob: panelresolution=1080 type=3
[0002.941] decompressor handler not found
[0002.945] load_firmware_blob: Firmware blob loaded, entries=2
[0002.951] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.957] -------> se_aes_verify_sbk_clear: 747
[0002.961] se_aes_verify_sbk_clear: Error
[0002.965] SE operation failed
[0002.968] bl_battery_charging: connected to external power supply
[0002.980] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.988] MSC Partition not found
[0002.994] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.001] USP partition read failed!
[0003.005] blob_init: blob-partition USP header read failed
[0003.010] android_boot Unable to update recovery partition
[0003.016] kfs_getpartname: name = LNX
[0003.019] Loading kernel from LNX
[0003.029] Found 19 BFS partitions in “spiflash0”
[0003.350] load kernel from storage
[0003.355] decompressor handler not found
[0003.621] Successfully loaded kernel and ramdisk images
[0003.626] board ID = D78, board SKU = 0
[0003.631] sdmmc node status = okay
[0003.634] sdcard instance = 0
[0003.637] sdcard gpio handle 0x5a
[0003.641] sdcard gpio pin 0xc9
[0003.643] sdcard gpio flags 0x0
[0003.647] vmmc-supply 0x9d
[0003.649] cd_gpio_pin = 201
[0003.652] pin_state = 0
[0003.654] Found sdcard
[0003.656] SD-card IS present …
[0003.660] load_and_boot_kernel: SD card detected OK
[0003.665] load_bmp_blob: panelresolution=1080 type=3
[0004.161] display bmp image done
[0004.164] NCK carveout not present
[0004.168] Skipping dts_overrides
[0004.171] NCK carveout not present
[0004.181] Find /i2c@7000c000’s alias i2c0
[0004.185] get eeprom at 1-a0, size 256, type 0
[0004.194] Find /i2c@7000c500’s alias i2c2
[0004.197] get eeprom at 3-a0, size 256, type 0
[0004.202] get eeprom at 3-ae, size 256, type 0
[0004.206] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.212] I2C slave not started
[0004.215] I2C write failed
[0004.217] Writing offset failed
[0004.220] eeprom_init: EEPROM read failed
[0004.224] pm_ids_update: eeprom init failed
[0004.228] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.258] pm_ids_update: The pm board id is 3448-0000-400
[0004.265] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.274] pm_ids_update: pm id update successful
[0004.278] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.309] pm_ids_update: The pm board id is 3449-0000-400
[0004.315] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.323] pm_ids_update: pm id update successful
[0004.353] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.359] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.367] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.373] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.381] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0004.387] Plugin Manager: Parse ODM data 0x000a4000
[0004.401] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.409] Add serial number:1422919145299 as DT property
[0004.418] “bpmp” doesn’t exist, creating
[0004.424] Updated bpmp info to DTB
[0004.429] Updated initrd info to DTB
[0004.432] “proc-board” doesn’t exist, creating
[0004.438] Updated board info to DTB
[0004.442] “pmu-board” doesn’t exist, creating
[0004.448] Updated board info to DTB
[0004.451] “display-board” doesn’t exist, creating
[0004.457] Updated board info to DTB
[0004.461] “reset” doesn’t exist, creating
[0004.465] Updated reset info to DTB
[0004.469] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1
[0004.508] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.514] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.527] Updated bootarg info to DTB
[0004.530] Adding uuid 0000000164456809200000000ffc8240 to DT
[0004.536] Adding eks info 0 to DT
[0004.542] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.548] Updated memory info to DTB
[0004.556] set vdd_core voltage to 1075 mv
[0004.560] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.565] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Jun 14 2021 - 11:29:25 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano 2GB Developer Kit
Board: NVIDIA P3541-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 26 ms (31.3 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 328 ms (20.8 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1503 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 00000000831843cf
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[0000.159] [L4T TegraBoot] (version 00.00.2018.01-l4t-dd84d362)
[0000.164] Processing in cold boot mode Bootloader 2
[0000.169] A02 Bootrom Patch rev = 1023
[0000.173] Power-up reason: software reset
[0000.176] No Battery Present
[0000.179] pmic max77620 reset reason
[0000.182] pmic max77620 NVERC : 0x0
[0000.186] RamCode = 0
[0000.188] Platform has DDR4 type RAM
[0000.191] max77620 disabling SD1 Remote Sense
[0000.195] Setting DDR voltage to 1125mv
[0000.199] Serial Number of Pmic Max77663: 0x830e6
[0000.207] Entering ramdump check
[0000.210] Get RamDumpCarveOut = 0x0
[0000.213] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.218] Last reboot was clean, booting normally!
[0000.223] Sdram initialization is successful
[0000.227] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.233] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.239] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.245] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.251] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.257] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.262] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.268] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.284] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.290] Platform-DebugCarveout: 0
[0000.294] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.299] Non secure mode, and RB not enabled.
[0000.304] BoardID = 3448, SKU = 0x0
[0000.307] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.311] Nano-SD: checking PT table on QSPI …
[0000.315] Read PT from (2:0)
[0000.331] Using BFS PT to query partitions
[0000.336] Loading Tboot-CPU binary
[0000.365] Verifying TBC in OdmNonSecureSBK mode
[0000.375] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.382] Bootloader downloaded successfully.
[0000.386] Downloaded Tboot-CPU binary to 0xa0000258
[0000.391] MAX77620_GPIO5 configured
[0000.394] CPU power rail is up
[0000.397] CPU clock enabled
[0000.401] Performing RAM repair
[0000.404] Updating A64 Warmreset Address to 0xa00002e9
[0000.409] BoardID = 3448, SKU = 0x0
[0000.412] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.416] Nano-SD: checking PT table on QSPI …
[0000.420] Loading NvTbootBootloaderDTB
[0000.487] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.567] Bootloader DTB Load Address: 0x83000000
[0000.571] BoardID = 3448, SKU = 0x0
[0000.575] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.578] Nano-SD: checking PT table on QSPI …
[0000.583] Loading NvTbootKernelDTB
[0000.649] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.729] Kernel DTB Load Address: 0x83100000
[0000.733] BoardID = 3448, SKU = 0x0
[0000.736] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.740] Nano-SD: checking PT table on QSPI …
[0000.746] Loading cboot binary
[0000.862] Verifying EBT in OdmNonSecureSBK mode
[0000.904] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.911] Bootloader downloaded successfully.
[0000.915] BoardID = 3448, SKU = 0x0
[0000.918] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.922] Nano-SD: checking PT table on QSPI …
[0000.927] PT: Partition NCT NOT found !
[0000.930] Warning: Find Partition via PT Failed
[0000.935] Next binary entry address: 0x92c00258
[0000.939] BoardId: 3448
[0000.944] Overriding pmu board id with proc board id
[0000.948] Display board id is not available
[0000.953] BoardID = 3448, SKU = 0x0
[0000.956] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.960] Nano-SD: checking PT table on QSPI …
[0001.065] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.124] /bpmp deleted
[0001.126] SC7EntryFw header found loaded at 0xff700000
[0001.322] OVR2 PMIC
[0001.323] Bpmp FW successfully loaded
[0001.327] BoardID = 3448, SKU = 0x0
[0001.330] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.334] Nano-SD: checking PT table on QSPI …
[0001.339] WB0 init successfully at 0xff780000
[0001.344] Set NvDecSticky Bits
[0001.347] GSC2 address ff53fffc value c0edbbcc
[0001.353] GSC MC Settings done
[0001.356] BoardID = 3448, SKU = 0x0
[0001.360] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.363] Nano-SD: checking PT table on QSPI …
[0001.369] TOS Image length 53680
[0001.372] Monitor size 53680
[0001.375] OS size 0
[0001.390] Secure Os AES-CMAC Verification Success!
[0001.394] TOS image cipher info: plaintext
[0001.398] Loading and Validation of Secure OS Successful
[0001.414] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.419] NvTbootPackSdramParams: start.
[00
[0000.949] Display board id is not available
[0001.324] Bpmp FW successfully loaded
[0001.354] GSC MC Settings done
[0001.364] Nano-SD: checking PT table on QSPI …
[0001.395] TOS image cipher info: plaintext
[0001.424] NvTbootPackSdramParams: done.
[0001.428] Tegraboot started after 86960 us
[0001.432] Basic modules init took 901092 us
[0001.436] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.441] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.447] Next stage binary read took 102860 us
[0001.451] Carveout took -126356 us
[0001.454] CPU initialization took 498062 us
[0001.458] Total time taken by TegraBoot 1375658 us
[0001.463] Starting CPU & Halting co-processor
[0001.586] RamCode = 0
[0001.588] get_emc_table_offset: Can’t find emc-table node
[0001.593] LPDDR4 Training: Can’t find emc-table node
[0001.639]
[0001.640] Debug Init done
[0001.643] Marked DTB cacheable
[0001.646] Bootloader DTB loaded at 0x83000000
[0001.651] Marked DTB cacheable
[0001.654] Kernel DTB loaded at 0x83100000
[0001.658] DeviceTree Init done
[0001.670] Pinmux applied successfully
[0001.675] gicd_base: 0x50041000
[0001.678] gicc_base: 0x50042000
[0001.681] Interrupts Init done
[0001.685] Using base:0x60005090 & irq:208 for tick-timer
[0001.691] Using base:0x60005098 for delay-timer
[0001.695] platform_init_timer: DONE
[0001.699] Timer(tick) Init done
[0001.702] osc freq = 38400 khz
[0001.706]
[0001.707] Welcome to L4T Cboot
[0001.710]
[0001.711] Cboot Version: 00.00.2018.01-t210-39562017
[0001.716] calling constructors
[0001.719] initializing heap
[0001.722] initializing threads
[0001.725] initializing timers
[0001.728] creating bootstrap completion thread
[0001.732] top of bootstrap2()
[0001.735] CPU: ARM Cortex A57
[0001.738] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.743] initializing platform
[0001.750] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.755] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.759] Macronix QSPI chip present
[0001.763] SPI device register
[0001.766] init boot device
[0001.768] allocating memory for boot device(SPI)
[0001.773] registering boot device
[0001.781] QSPI bdev is already initialized
[0001.785] Enable APE clock
[0001.788] Un-powergate APE partition
[0001.791] of_register: registering tegra_udc to of_hal
[0001.796] of_register: registering inv20628-driver to of_hal
[0001.802] of_register: registering ads1015-driver to of_hal
[0001.807] of_register: registering lp8557-bl-driver to of_hal
[0001.813] of_register: registering bq2419x_charger to of_hal
[0001.819] of_register: registering bq27441_fuel_gauge to of_hal
[0001.830] gpio framework initialized
[0001.834] of_register: registering tca9539_gpio to of_hal
[0001.839] of_register: registering tca9539_gpio to of_hal
[0001.845] of_register: registering i2c_bus_driver to of_hal
[0001.850] of_register: registering i2c_bus_driver to of_hal
[0001.856] of_register: registering i2c_bus_driver to of_hal
[0001.861] pmic framework initialized
[0001.865] of_register: registering max77620_pmic to of_hal
[0001.870] regulator framework initialized
[0001.874] of_register: registering tps65132_bl_driver to of_hal
[0001.880] initializing target
[0001.886] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.894] board ID = D78, board SKU = 0
[0001.898] Skipping Z3!
[0001.903] fixed regulator driver initialized
[0001.921] initializing OF layer
[0001.924] NCK carveout not present
[0001.928] Skipping dts_overrides
[0001.932] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.949] I2C Bus Init done
[0001.952] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.962] I2C Bus Init done
[0001.965] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.975] I2C Bus Init done
[0001.978] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.988] I2C Bus Init done
[0001.991] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.001] I2C Bus Init done
[0002.004] of_children_init: Ops found for compatible string maxim,max77620
[0002.014] max77620_init using irq 118
[0002.019] register ‘maxim,max77620’ pmic
[0002.023] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.030] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.040] I2C Bus Init done
[0002.044] NCK carveout not present
[0002.054] Find /i2c@7000c000’s alias i2c0
[0002.057] get eeprom at 1-a0, size 256, type 0
[0002.066] Find /i2c@7000c500’s alias i2c2
[0002.070] get eeprom at 3-a0, size 256, type 0
[0002.075] get eeprom at 3-ae, size 256, type 0
[0002.079] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.084] I2C slave not started
[0002.087] I2C write failed
[0002.090] Writing offset failed
[0002.093] eeprom_init: EEPROM read failed
[0002.097] pm_ids_update: eeprom init failed
[0002.101] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.131] pm_ids_update: The pm board id is 3448-0000-400
[0002.138] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.147] pm_ids_update: pm id update successful
[0002.151] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.181] pm_ids_update: The pm board id is 3449-0000-400
[0002.188] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.196] pm_ids_update: pm id update successful
[0002.226] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.232] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.240] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.246] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.254] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0002.260] Plugin Manager: Parse ODM data 0x000a4000
[0002.273] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.288] Find /i2c@7000c000’s alias i2c0
[0002.292] get eeprom at 1-a0, size 256, type 0
[0002.301] Find /i2c@7000c500’s alias i2c2
[0002.305] get eeprom at 3-a0, size 256, type 0
[0002.309] get eeprom at 3-ae, size 256, type 0
[0002.314] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.319] I2C slave not started
[0002.322] I2C write failed
[0002.325] Writing offset failed
[0002.328] eeprom_init: EEPROM read failed
[0002.332] pm_ids_update: eeprom init failed
[0002.336] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.366] pm_ids_update: The pm board id is 3448-0000-400
[0002.372] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.379] pm_ids_update: pm id update successful
[0002.384] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.414] pm_ids_update: The pm board id is 3449-0000-400
[0002.420] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.427] pm_ids_update: pm id update successful
[0002.457] Add serial number:1422919145299 as DT property
[0002.465] Applying platform configs
[0002.472] platform-init is not present. Skipping
[0002.476] calling apps_init()
[0002.482] Couldn’t find GPT header
[0002.487] Proceeding to Cold Boot
[0002.490] starting app android_boot_app
[0002.494] Device state: unlocked
[0002.497] display console init
[0002.505] could not find regulator
[0002.508] hdmi cable connected
[0002.524] edid read success
[0002.541] DT entry for leds-pwm not found
[0002.545] edid read success
[0002.548] width = 640, height = 480, frequency = 25174825
[0002.553] width = 640, height = 480, frequency = 25174825
[0002.559] width = 640, height = 480, frequency = 25174825
[0002.564] width = 640, height = 480, frequency = 25174825
[0002.569] width = 1920, height = 1080, frequency = 148500000
[0002.575] width = 1280, height = 720, frequency = 74250000
[0002.580] width = 1920, height = 540, frequency = 74250000
[0002.586] width = 1920, height = 1080, frequency = 148351648
[0002.592] width = 1280, height = 720, frequency = 74175824
[0002.597] width = 1920, height = 1080, frequency = 148351648
[0002.603] width = 1280, height = 720, frequency = 74175824
[0002.608] width = 720, height = 576, frequency = 26973026
[0002.613] width = 720, height = 480, frequency = 26973026
[0002.619] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.627] tmds-config node not found
[0002.631] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.645] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.653] could not find regulator
[0002.656] could not find regulator
[0002.660] could not find regulator
[0002.688] using default cmu settings
[0002.691] dc_hdmi_enable, starting HDMI initialisation
[0002.698] dc_hdmi_enable, HDMI initialisation complete
[0002.703] list and configure display window
[0002.711] display console init completed
[0002.723] subnode volume_up is not found !
[0002.727] subnode back is not found !
[0002.730] subnode volume_down is not found !
[0002.735] subnode menu is not found !
[0002.738] Gpio keyboard init success
[0002.819] found decompressor handler: lz4-legacy
[0002.833] decompressing blob (type 1)…
[0002.903] load_bmp_blob: panelresolution=1080 type=3
[0002.978] decompressor handler not found
[0002.981] load_firmware_blob: Firmware blob loaded, entries=2
[0002.987] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.993] -------> se_aes_verify_sbk_clear: 747
[0002.998] se_aes_verify_sbk_clear: Error
[0003.002] SE operation failed
[0003.004] bl_battery_charging: connected to external power supply
[0003.017] device_query_partition_size: failed to open partition spiflash0:MSC !
[0003.024] MSC Partition not found
[0003.030] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.037] USP partition read failed!
[0003.041] blob_init: blob-partition USP header read failed
[0003.046] android_boot Unable to update recovery partition
[0003.052] kfs_getpartname: name = LNX
[0003.055] Loading kernel from LNX
[0003.065] Found 19 BFS partitions in “spiflash0”
[0003.386] load kernel from storage
[0003.391] decompressor handler not found
[0003.658] Successfully loaded kernel and ramdisk images
[0003.663] board ID = D78, board SKU = 0
[0003.667] sdmmc node status = okay
[0003.671] sdcard instance = 0
[0003.673] sdcard gpio handle 0x5a
[0003.677] sdcard gpio pin 0xc9
[0003.680] sdcard gpio flags 0x0
[0003.683] vmmc-supply 0x9d
[0003.685] cd_gpio_pin = 201
[0003.688] pin_state = 0
[0003.690] Found sdcard
[0003.693] SD-card IS present …
[0003.696] load_and_boot_kernel: SD card detected OK
[0003.702] load_bmp_blob: panelresolution=1080 type=3
[0004.198] display bmp image done
[0004.201] NCK carveout not present
[0004.204] Skipping dts_overrides
[0004.207] NCK carveout not present
[0004.217] Find /i2c@7000c000’s alias i2c0
[0004.221] get eeprom at 1-a0, size 256, type 0
[0004.230] Find /i2c@7000c500’s alias i2c2
[0004.234] get eeprom at 3-a0, size 256, type 0
[0004.238] get eeprom at 3-ae, size 256, type 0
[0004.242] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.248] I2C slave not started
[0004.251] I2C write failed
[0004.253] Writing offset failed
[0004.256] eeprom_init: EEPROM read failed
[0004.260] pm_ids_update: eeprom init failed
[0004.264] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.295] pm_ids_update: The pm board id is 3448-0000-400
[0004.301] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.310] pm_ids_update: pm id update successful
[0004.315] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.345] pm_ids_update: The pm board id is 3449-0000-400
[0004.351] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.359] pm_ids_update: pm id update successful
[0004.389] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.395] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.403] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.409] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.417] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0004.424] Plugin Manager: Parse ODM data 0x000a4000
[0004.437] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.445] Add serial number:1422919145299 as DT property
[0004.454] “bpmp” doesn’t exist, creating
[0004.460] Updated bpmp info to DTB
[0004.465] Updated initrd info to DTB
[0004.468] “proc-board” doesn’t exist, creating
[0004.475] Updated board info to DTB
[0004.478] “pmu-board” doesn’t exist, creating
[0004.484] Updated board info to DTB
[0004.487] “display-board” doesn’t exist, creating
[0004.493] Updated board info to DTB
[0004.497] “reset” doesn’t exist, creating
[0004.502] Updated reset info to DTB
[0004.505] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1
[0004.544] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.550] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.563] Updated bootarg info to DTB
[0004.566] Adding uuid 0000000164456809200000000ffc8240 to DT
[0004.572] Adding eks info 0 to DT
[0004.578] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.584] Updated memory info to DTB
[0004.592] set vdd_core voltage to 1075 mv
[0004.596] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.602] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
845 bytes read in 25 ms (32.2 KiB/s)
1: primary kernel
7159841 bytes read in 327 ms (20.9 MiB/s)
34338824 bytes read in 1502 ms (21.8 MiB/s)
Starting kernel …
[0000.566] Bootloader DTB Load Address: 0x83000000
[0000.574] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.728] Kernel DTB Load Address: 0x83100000
[0000.732] BoardID = 3448, SKU = 0x0
[0000.861] Verifying EBT in OdmNonSecureSBK mode
[0000.903] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.910] Bootloader downloaded successfully.
[0000.914] BoardID = 3448, SKU = 0x0
[0000.921] Nano-SD: checking PT table on QSPI …
[0000.926] PT: Partition NCT NOT found !
[0000.934] Next binary entry address: 0x92c00258
[0000.943] Overriding pmu board id with proc board id
[0000.952] BoardID = 3448, SKU = 0x0
[0000.955] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.959] Nano-SD: checking PT table on QSPI …
[0001.064] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.123] /bpmp deleted
[0001.321] OVR2 PMIC
[0001.326] BoardID = 3448, SKU = 0x0
[0001.333] Nano-SD: checking PT table on QSPI …
[0001.343] Set NvDecSticky Bits
[0001.359] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.368] TOS Image length 53680
[0001.371] Monitor size 53680
[0001.374] OS size 0
[0001.389] Secure Os AES-CMAC Verification Success!
[0001.418] NvTbootPackSdramParams: start.
[0001.423] NvTbootPackSdramParams: done.
[0001.427] Tegraboot started after 86963 us
[0001.431] Basic modules init took 900434 us
[0001.435] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.446] Next stage binary read took 102859 us
[0001.450] Carveout took -126353 us
[0001.454] CPU initialization took 497941 us
[0001.458] Total time taken by TegraBoot 1374881 us
[0001.462] Starting CPU & Halting co-processor
[0001.585] RamCode = 0
[0001.587] get_emc_table_offset: Can’t find emc-table node
[0001.592] LPDDR4 Training: Can’t find emc-table node
[0001.639]
[0001.642] Marked DTB cacheable
[0001.645] Bootloader DTB loaded at 0x83000000
[0001.650] Marked DTB cacheable
[0001.653] Kernel DTB loaded at 0x83100000
[0001.657] DeviceTree Init done
[0001.674] gicd_base: 0x50041000
[0001.690] Using base:0x60005098 for delay-timer
[0001.694] platform_init_timer: DONE
[0001.698] Timer(tick) Init done
[0001.705]
[0001.709]
[0001.721] initializing threads
[0001.724] initializing timers
[0001.727] creating bootstrap completion thread
[0001.731] top of bootstrap2()
[0001.734] CPU: ARM Cortex A57
[0001.737] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.742] initializing platform
[0001.749] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.754] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.758] Macronix QSPI chip present
[0001.762] SPI device register
[0001.765] init boot device
[0001.767] allocating memory for boot device(SPI)
[0001.772] registering boot device
[0001.780] QSPI bdev is already initialized
[0001.784] Enable APE clock
[0001.787] Un-powergate APE partition
[0001.790] of_register: registering tegra_udc to of_hal
[0001.801] of_register: registering ads1015-driver to of_hal
[0001.812] of_register: registering bq2419x_charger to of_hal
[0001.818] of_register: registering bq27441_fuel_gauge to of_hal
[0001.833] of_register: registering tca9539_gpio to of_hal
[0001.838] of_register: registering tca9539_gpio to of_hal
[0001.844] of_register: registering i2c_bus_driver to of_hal
[0001.849] of_register: registering i2c_bus_driver to of_hal
[0001.855] of_register: registering i2c_bus_driver to of_hal
[0001.864] of_register: registering max77620_pmic to of_hal
[0001.869] regulator framework initialized
[0001.873] of_register: registering tps65132_bl_driver to of_hal
[0001.879] initializing target
[0001.885] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.893] board ID = D78, board SKU = 0
[0001.897] Skipping Z3!
[0001.902] fixed regulator driver initialized
[0001.927] Skipping dts_overrides
[0001.931] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.948] I2C Bus Init done
[0001.951] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.961] I2C Bus Init done
[0001.964] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.974] I2C Bus Init done
[0001.977] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.987] I2C Bus Init done
[0001.990] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.000] I2C Bus Init done
[0002.003] of_children_init: Ops found for compatible string maxim,max77620
[0002.013] max77620_init using irq 118
[0002.018] register ‘maxim,max77620’ pmic
[0002.022] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.029] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.039] I2C Bus Init done
[0002.043] NCK carveout not present
[0002.053] Find /i2c@7000c000’s alias i2c0
[0002.065] Find /i2c@7000c500’s alias i2c2
[0002.069] get eeprom at 3-a0, size 256, type 0
[0002.074] get eeprom at 3-ae, size 256, type 0
[0002.078] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.083] I2C slave not started
[0002.086] I2C write failed
[0002.089] Writing offset failed
[0002.092] eeprom_init: EEPROM read failed
[0002.096] pm_ids_update: eeprom init failed
[0002.100] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.130] pm_ids_update: The pm board id is 3448-0000-400
[0002.137] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.146] pm_ids_update: pm id update successful
[0002.150] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.180] pm_ids_update: The pm board id is 3449-0000-400
[0002.187] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.195] pm_ids_update: pm id update successful
[0002.225] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.231] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.239] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.245] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.253] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0002.259] Plugin Manager: Parse ODM data 0x000a4000
[0002.272] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.287] Find /i2c@7000c000’s alias i2c0
[0002.291] get eeprom at 1-a0, size 256, type 0
[0002.300] Find /i2c@7000c500’s alias i2c2
[0002.304] get eeprom at 3-a0, size 256, type 0
[0002.313] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.318] I2C slave not started
[0002.321] I2C write failed
[0002.324] Writing offset failed
[0002.327] eeprom_init: EEPROM read failed
[0002.331] pm_ids_update: eeprom init failed
[0002.335] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.365] pm_ids_update: The pm board id is 3448-0000-400
[0002.371] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.378] pm_ids_update: pm id update successful
[0002.383] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.413] pm_ids_update: The pm board id is 3449-0000-400
[0002.419] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.426] pm_ids_update: pm id update successful
[0002.456] Add serial number:1422919145299 as DT property
[0002.464] Applying platform configs
[0002.471] platform-init is not present. Skipping
[0002.481] Couldn’t find GPT header
[0002.486] Proceeding to Cold Boot
[0002.489] starting app android_boot_app
[0002.493] Device state: unlocked
[0002.496] display console init
[0002.504] could not find regulator
[0002.523] edid read success
[0002.540] DT entry for leds-pwm not found
[0002.544] edid read success
[0002.547] width = 640, height = 480, frequency = 25174825
[0002.552] width = 640, height = 480, frequency = 25174825
[0002.558] width = 640, height = 480, frequency = 25174825
[0002.563] width = 640, height = 480, frequency = 25174825
[0002.574] width = 1280, height = 720, frequency = 74250000
[0002.585] width = 1920, height = 1080, frequency = 148351648
[0002.591] width = 1280, height = 720, frequency = 74175824
[0002.596] width = 1920, height = 1080, frequency = 148351648
[0002.602] width = 1280, height = 720, frequency = 74175824
[0002.607] width = 720, height = 576, frequency = 26973026
[0002.618] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.626] tmds-config node not found
[0002.630] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.652] could not find regulator
[0002.659] could not find regulator
[0002.687] using default cmu settings
[0002.697] dc_hdmi_enable, HDMI initialisation complete
[0002.702] list and configure display window
[0002.722] subnode volume_up is not found !
[0002.726] subnode back is not found !
[0002.729] subnode volume_down is not found !
[0002.734] subnode menu is not found !
[0002.737] Gpio keyboard init success
[0002.818] found decompressor handler: lz4-legacy
[0002.832] decompressing blob (type 1)…
[0002.902] load_bmp_blob: panelresolution=1080 type=3
[0002.977] decompressor handler not found
[0002.986] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.997] se_aes_verify_sbk_clear: Error
[0003.001] SE operation failed
[0003.016] device_query_partition_size: failed to open partition spiflash0:MSC !
[0003.023] MSC Partition not found
[0003.029] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.040] blob_init: blob-partition USP header read failed
[0003.051] kfs_getpartname: name = LNX
[0003.064] Found 19 BFS partitions in “spiflash0”
[0003.382] load kernel from storage
[0003.387] decompressor handler not found
[0003.650] Successfully loaded kernel and ramdisk images
[0003.655] board ID = D78, board SKU = 0
[0003.660] sdmmc node status = okay
[0003.663] sdcard instance = 0
[0003.666] sdcard gpio handle 0x5a
[0003.669] sdcard gpio pin 0xc9
[0003.672] sdcard gpio flags 0x0
[0003.675] vmmc-supply 0x9d
[0003.678] cd_gpio_pin = 201
[0003.681] pin_state = 0
[0003.683] Found sdcard
[0003.685] SD-card IS present …
[0003.688] load_and_boot_kernel: SD card detected OK
[0003.694] load_bmp_blob: panelresolution=1080 type=3
[0004.190] display bmp image done
[0004.193] NCK carveout not present
[0004.196] Skipping dts_overrides
[0004.200] NCK carveout not present
[0004.209] Find /i2c@7000c000’s alias i2c0
[0004.213] get eeprom at 1-a0, size 256, type 0
[0004.222] Find /i2c@7000c500’s alias i2c2
[0004.226] get eeprom at 3-a0, size 256, type 0
[0004.231] get eeprom at 3-ae, size 256, type 0
[0004.235] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.240] I2C slave not started
[0004.243] I2C write failed
[0004.246] Writing offset failed
[0004.249] eeprom_init: EEPROM read failed
[0004.253] pm_ids_update: eeprom init failed
[0004.257] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.287] pm_ids_update: The pm board id is 3448-0000-400
[0004.294] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.303] pm_ids_update: pm id update successful
[0004.307] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.337] pm_ids_update: The pm board id is 3449-0000-400
[0004.344] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.352] pm_ids_update: pm id update successful
[0004.382] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.388] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.396] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.402] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.410] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0004.416] Plugin Manager: Parse ODM data 0x000a4000
[0004.429] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.438] Add serial number:1422919145299 as DT property
[0004.447] “bpmp” doesn’t exist, creating
[0004.453] Updated bpmp info to DTB
[0004.457] Updated initrd info to DTB
[0004.461] “proc-board” doesn’t exist, creating
[0004.467] Updated board info to DTB
[0004.471] “pmu-board” doesn’t exist, creating
[0004.477] Updated board info to DTB
[0004.480] “display-board” doesn’t exist, creating
[0004.486] Updated board info to DTB
[0004.489] “reset” doesn’t exist, creating
[0004.494] Updated reset info to DTB
[0004.497] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1
[0004.537] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.542] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.555] Updated bootarg info to DTB
[0004.559] Adding uuid 0000000164456809200000000ffc8240 to DT
[0004.565] Adding eks info 0 to DT
[0004.570] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.576] Updated memory info to DTB
[0004.584] set vdd_core voltage to 1075 mv
[0004.588] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.594] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Tegra210 (P3541-0000) #
