Hi!
I am facing the issue of the whole row of connector ports (HDMI, USB, Ethernet etc) not lighting up and it’s not working, while the light indicator of main power remains on. Two unit of Jetson Nano under different condition, faced the same issue, below are some elaborations:-
Case 1
- It’s connected to power supply unit of 5V, 10A, shared between two units of jetson nano, the aforementioned issue happenned on one of the unit.
- Both units constantly having overcurrent warning, does this related to the mentioned connector issue?
(Checked with multimeter, those having this warning is on 5.08V while power plug that having 5.16V & 5.18V didn’t show the overcurrent (under voltage) notification) - Both are not running on any application yet.
Case 2
- Powered by direct plug 5V, 4A. No overcurrent notification but similar situation happens after using for a while.
Remarks:
Both units are having the jumper on J48 & it’s powered by Barrel Jack connection.
Focus:-
- Ethernet, USB, HDMI is not working
- Overcurrent notification (suspecting under voltage) while connected to 5V 4A power supply.
Found the threads of previous post, the problem seems like more focusing on powering up option between barrel jack & microB.
Jetson nano all usb,hdmi not working - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
